Everyone has thier preference. I like Iwata cause I used to sell them, and know them really well. This is the CM-B. It's a variation on the Iwata HP-B I bought 20 years ago and still works perfect. I have another exactly the same with the brand name Olympia, and like having 2 detail AB's with interchangable parts. Never find a finer line delivering arirbrush anywhere, especially if you get up really close(even finer w/o tipguard) Another Iwata to consider is the CM-C,
which is nearly the same gun with a larger paint cup.(handy often enough,but not as light in the hand) Both give very fine detail, but the 'B' is finer.(.19mm needle/nozzle) The 'C' (.23mm) Parts aren't cheap, so loaning these out is not recommended, but again, for fine work, these are the bomb.
These guys have an unbielvable selection of models these days, check 'em out....
http://www.iwata-medea.com/
