Your thoughts on using metalizer sealers?
Posted by echolmberg on Tuesday, September 15, 2009 9:13 AM
Hi guys!
I just finished applying the finish to a natural metal P-51.  I laid down a gloss white base coat with some of the panels picked out in gloss black.  I then applied some SnJ metal powder.  I'm happy with the result but I'm thinking it's leaning a bit on the "almost too mirror-like" side.  It's not bad but....
Anyway, I was wondering what would it do to the finish if I were to apply a metalizer sealer?  I once applied a dulcote over a natural metal finish and the silver went from being shiny to almost a dull grey!  Ugh!  I don't want that to happen again.  I don't mind of the shininess of my finish is reduced a wee bit but I don't want it gone altogether.
Also, IF I were to apply it, should I apply it before or after the decals are applied?
Thank you!
Eric
    April 2005
Posted by T_Terrific on Tuesday, September 15, 2009 9:21 AM
Have you tried a semi-gloss instead of a dullcoat?
Tom T Cowboy [C):-)]
Tom TCowboy
“Failure is the opportunity to begin again more intelligently.”-Henry Ford
"Except in the fundamentals, think and let think"- J. Wesley
"I am impatient with stupidity, my people have learned to live without it"-Klaatu: "The Day the Earth Stood Still"
"All my men believe in God, they are ordered to"-Adolph Hitler
    August 2006
Posted by HawkeyeHobbies on Tuesday, September 15, 2009 9:39 AM
Take a cotton ball dampened with water...you should be able to ease the sheen back a bit. I'd put the decals on first before sealing the surface. You can seal with Future or any other sealer of your choice.
Gerald "Hawkeye" Voigt
Posted by echolmberg on Tuesday, September 15, 2009 10:37 AM
Tom, please don't ask me why I tried a dulcote rather than a semi-gloss or satin finish.  I'm sure I would have gotten better results from that instead.  It must have been too many days with the cap off the glue.  LOL!
Gerald, thanks for the info!  I never would have thought about the wet cotton ball trick.  I'll give that one a try.  Also, thanks for the info about being able to put the sealer on after the decals have been applied.  I've never used the metalizer sealers before so I wasn't sure what the correct order of doing things was.
Eric
