Ok, so I saw this double action air-brush at Harbor Freight for $20! I know their stuff is usually imported Chinese crap, but this didn't look all that bad. I took it home, hooked it up to try it out. It really didn't do all that bad at all! For the price, if it works for a while, then quits-I'm not out all that much. I just have to learn to use it, as I have been using a Badger 350 for over 15 years. It has been a workhorse for me. Getting used to the trigger and not pulling back too far is a learning curve for me.
My question is this: The instuctions that came with the new one are vague as far as maintaining and cleaning. They pretty much just say to "wash it out". We all know it is nessessary to break them down to clean them. I don't know just how far to disassemble it. I unscrewed a tip and the nozzle from the front and loosened the needle at the back to pull it out and wipe it. As far as I can tell, I think those are the only parts the paint really touches. I assume that is sufficiant to clean it. Also, the way the needle is mounted in the back (looks similar the open design of a Badger Anthem) is intended as an adjustment or is the needle just replaced back in to close off the nozzle and tightened? I'm guessing this is a design that just aids in easier removal of the needle.
As soon as I need to do some painting, I'll have to let you know of the results. For now I am decaling the SU-27 and we all know how tedious that can be!
