tamiyas rattlecans
    July 2009
tamiyas rattlecans
Posted by trakpin on Saturday, September 26, 2009 6:30 AM
there some trick to them, or do they all spray and adhere like a faint mist? took their dark yellow to some road wheels still on the sprue and thats what i got, a misting of sorts. the grey of the plastic can still be seen. the nozzle wasn't too far, nor too close,  away for that as i've used MM rattlecans previously and the sprayed very well. just havm't see MM dark yellow or i likely woulda gotten that instead. thx
SI VIS PACEM, PAILA BELLUM
    October 2005
Posted by usmc1371 on Saturday, September 26, 2009 6:49 AM
Here's a couple of things to think about.
  • Tamiya's spray paint is lacquer based.  If you're just a little too far away, the paint will start to dry before contact.  Lacquer based paint can dry a lot faster than enamel based.
  • Have you tried to clean the inside of the nozzle?
  • Maybe the can has lost propellent.  I've seen this happen.
  • Yellow can be hard to paint and it may take a few coats for complete coverage.
    July 2009
Posted by trakpin on Saturday, September 26, 2009 1:07 PM
thx. that last i was thinking possible, maybe somewhere like 20-30 coatsCensored [censored]. no prob with pressure and no blockage of the nozzle. we'll see what happens
    September 2007
Posted by firesmacker on Saturday, September 26, 2009 4:35 PM
Remember, when you are spraying yellow, your best bet is a primer coat of either grey or white. It doesn't even really have to be primer, an undercoat of white or grey paint will work just as well although primer will help acrylic paint adhere better. Try one of those methods before you spray a whole bunch of coats. I would hate for you to lose a bunch of detail because of too many layers of paint. Hope this helps and good luck.
Regards,
Jeff
    July 2009
Posted by trakpin on Sunday, September 27, 2009 6:09 AM
yeah, i was thinking about primer, but i wouldn't be lookin forward to brushing it on. anyway, under a different light source the can didn't do too half bad after all so maybe it'll just take 2 or maybe 3 coats overall. actually, gonna need primer anyway for the PE. fortunatrly i already ave a bottleDinner [dinner]
    May 2005
Posted by Bgrigg on Sunday, September 27, 2009 8:11 AM
Tamiya fine grey primer is available in a rattle can and works wonderfully.
I've also used their AS-12 bare metal silver with great results. No need to brush it on!
So long folks!
    July 2009
Posted by trakpin on Sunday, September 27, 2009 2:29 PM
i don't recall seeing it on the shelf. i've rattlecanned before w/out primer, MM, and it turned out quite well so, we'll see...
    September 2007
Posted by firesmacker on Sunday, September 27, 2009 2:54 PM
You were using an enamal paint. You don't really "need" to prime before enamals they bite into the plastic just fine without priming. With acrylics primer helps the paint stick better. You can get primer from any hardware or automotive store. It doesn't have to be Tamiya, I use both. Good luck.
Regards,
Jeff
