Is it me or the paint?
    July 2009
Posted by Hsnopi on Saturday, September 26, 2009 10:38 PM
Ok so upon your alls advice I went and got some medium to keep the paint from drying too fast. I was having dry tip issues.
I paint with acrylics and I paint Warhammer 40,000 minis and some N scale train stuff. I have a badger 350 and run it at about 30 psi. with a quality regulator.
I had it all cleaned out and found there was some dried up paint from 15 years ago in the tip. I was using Citadel Paints but I know they are a particulate pigment paint. I had a jar of Forumula P3 so I tried that. It seemed to work better at first. After thoroughly cleaning the tip it came out and quickly pooled and it wasn't even. I went over the stuff quickly so I didn't hold it in one place long or anything. Is it me or do I need a better paint? (or both)
    January 2003
Posted by Triarius on Monday, September 28, 2009 3:08 PM
I'm not sure what Formula P3 is, but your pressure seems way too high, for one thing. For a gravity fed airbrush, use about 15 psi. For gravity fed, you might go down to 10 psi.
Anther problem might be using too much retarder. You need about 0.5 ml or less (half a drop) per5 to 10 ml of paint.
    August 2005
Posted by Phil_H on Monday, September 28, 2009 8:27 PM
Ross,
I think you may be getting your AB's mixed up - the B-350 is a single-action siphon feed external mix model. Anything in the 20-30psi range should be ok for this model.
Hsnopi
It may be a simple case of having the nozzle set too far open, being too close to the subject and/or roo high air pressure. Though I said above that anywhere 20-30psi should work, knock it back down to about 22psi and go from there. Try varying by up to about +/- 4psi either way and see how that affects your results
    January 2003
Posted by Triarius on Monday, September 28, 2009 9:11 PM
Thanks, Phil. I meant to say "gravity fed" followed by "siphon"—but I'm on some fairly strong meds, right now. Confused [%-)]
"Price check on prune juice, Bob?"
    July 2009
Posted by Hsnopi on Monday, September 28, 2009 10:56 PM
strong meds are fun.
Formula P3 is a paint for minis. I am wondering if I should just go get a pot of vallejo and see how it works. I put in 2-3 drops of retarder so that sounds like I put in waaay too much. *sigh* I have been fighting this thing for a month and am about to lose my mind. I swear I wanna jsut give up. I can't even get a good spray.
It just needs to be acrylic so i can use my citadel paints wiht them. I am not about to spend another $200 on paints I have collected over the years. I really want to use it to make a good base coat. If I can do mroe with it that would be awesome.
