Acrylic wash over Future
    May 2006
Posted by Shipwreck on Wednesday, September 30, 2009 8:30 PM
I understand that we do not want to do an acrylic wash over an acrylic base. But we can do an acrylic wash over Future. If that understanding is correct, then there is no reason why we cannot do an acrylic was over Future which is sealing an acrylic base. Is this correct?
Thank you!
On the Bench:
Revell 1/96 USS Constitution - rigging
Revell 1/48 B-1B Lancer Prep and research
Trumpeter 1/350 USS Hornet CV-8 Prep and research
    January 2009
Posted by eptingmike on Wednesday, September 30, 2009 8:48 PM
I believe the main issue with acrylic on acrylic is making sure that it is fully cured.  Once cured, acrylics are pretty tough paints really.
Horten_IX_Go-229
Posted by kielers on Thursday, October 1, 2009 3:35 AM
Yes, this is correct.  You can do an acrylic wash over Future over acrylic finish.  Future is pretty tough and you can pretty much do any kind of wash over it, as long as you let it dry and harden enough.  I usually wait at least 24 hours before applying a wash or anything else over Future.
"To stand upon ramparts and die for our principles is heroic, but to sally forth to battle and win for our principles is something more than heroic." -- Franklin Delano Roosevelt. "Never in the field of human conflict was so much owed by so many to so few." -- Winston Churchill
    January 2003
Posted by Triarius on Thursday, October 1, 2009 12:59 PM
I must disagree to some extent with the previous posters. Future is an acrylic coating. You can put an acrylic wash over it, but the brand of paint you use for the wash is critical. Do not use an alcohol solvent acrylic (Tamiya, Gunze, possibly others) over Future. Future is soluble in most common alcohols, and using an alcohol solvent paint over it will immediately dissolve the Future. Use an aqueous solvent (water soluble) paint wash over Future.
Posted by MikeV on Thursday, October 1, 2009 5:15 PM
Good points Ross.
That is why I use Createx acrylic T-shirt paints for my washes over the Future.
They are water-based and almost don't stick well enough after thinned out and a drop of Dawn dishwashing liquid is added. It allows for easy removal if you make mistakes.
  • From: 41 Degrees 52.4 minutes North; 72 Degrees 7.3 minutes West
Posted by bbrowniii on Thursday, October 1, 2009 6:16 PM
While that may be the case, I have NEVER had that issue.  I use Tamiya paints, almost exclusively.  When (and I don't always) I use a Future base, so long as I let it cure fully (24 - 48 hours) I have never had a problem.  I also commonly do an acrylic over acrylic wash (Tamiya on Tamiya - again fully cured) and have never had a problem....
'All that is necessary for the triumph of evil is for good men to do nothing' - Edmund Burke (1770 ??)
    January 2003
Posted by Triarius on Thursday, October 1, 2009 10:15 PM
Fully cured Future is much more resistant to any solvent, and the same applies to a lesser degree to Tamiya acrylics. However, I suspect that your wash technique is better than most—I've done the same things you have. But I don't recommend the procedure to those of less experience!Wink [;)]
