How to paint this.......
    October 2009
Posted by juststartin' on Monday, October 5, 2009 1:16 AM
Hi, I was wondering on how you guys paint these kinds of lines (encircled ones). I'm not really good in painting with my hands really steady. Definitely I would paint some outside the line.
    August 2005
Posted by Phil_H on Monday, October 5, 2009 1:43 AM
There are a number of options available, including:
  • localised wash using thinned paint
  • very fine point marking pen
  • draftsman's pen
  • draftsman's ink bow
With the two latter options, if you use Indian ink to fill the lines, if there is any overflow or uneven application, you can simply use a damp paper towel to remove the excess (assuming that it's been applied to a glossy surface - if applied to a flat surface it may leach into the surface and will be difficult to remove)
    August 2009
Posted by robiwon on Monday, October 5, 2009 10:43 AM
You could also use very thin pinstriping tape made by Chartpac.
    August 2006
Posted by HawkeyeHobbies on Monday, October 5, 2009 10:54 AM
You could apply a dark wash to the model before decaling if these are recessed panel lines. Or use a technical pen. These are available at most higher end craft stores as well as office supply stores. Three sizes you need: 0, 00 and 000.
Gerald "Hawkeye" Voigt
    January 2007
Posted by Gigatron on Monday, October 5, 2009 12:09 PM
Easiest stuff I found to use is Promodeller's weathering wash - goes on easy, cleans up easy.  I've used it on most of my builds as I can't figure out ratios of paint/thinner/dish soap to make a decent wash.
http://www.promodeller.com/promodellers-weathering-wash/
-Fred
    October 2009
Posted by juststartin' on Monday, October 5, 2009 7:03 PM
Thanks Guys for your help and I think I'll go with the Promodellers way. Safer for me.
