Weathering and wash ?'s
    May 2009
Posted by 75th Ranger on Tuesday, October 6, 2009 3:16 PM
What should i use and how should i weather this Italiari 1/48 T6G Texan, and how do i put a wash on here and what should do i use, i've never done a wash and what i've read is kinda vauge and not really wanting to try something without understanding how to do it, thanks alot.
Jason
Rangers Lead the Way!!
    August 2006
Posted by HawkeyeHobbies on Tuesday, October 6, 2009 7:25 PM
A little light exhaust streaking is all I would give it. Training command aircraft were usually well cared for. They were classrooms for the maintainers as well as the student pilots.
Gerald "Hawkeye" Voigt
    July 2004
Posted by stikpusher on Tuesday, October 6, 2009 7:27 PM
there are two type of washes: an overall wash and a pin wash. The overall wash is just that, using the wash to coat the entire surface chosen. A pin wash is used to get the wash in a specific area- panel line, two adjoining surfaces, around a rasied detail, etc.
A good idea is to perhaps practice your techniques on an old model before you try it on a more prized build in progress.
First, make sure your base paint job has had lots of time to dry and CURE. Usually several days.
For the overall wash, a wide flat brush is best used. For the pin wash, a small pointed brush of size 0 or smaller. On the pin wash, a pre wash of clean thinner overall immediately before the pin wash will allow the pin wash to flow better and reduce the "pooling" marks that can occur.
After applying the wash and giving it a short time to dry, use a brush lightly moistened with clean thinner to remove excess wash.
I prefer doing my washes with enamels, but you can do the same with acrylics. just beware that some acrylic thinners (gunze in particular) will remove the paint below in addition to any excess wash.
A good idea is to use a clear coat beneath the wash opposite of the type of wash being used- enamel or lacquer below acrylic, and vice versa.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    May 2009
Posted by 75th Ranger on Wednesday, October 7, 2009 3:08 PM
Thanks alot that helps me kinda understand how you aply the wash should you thin the paint you're using to wash with?
    July 2004
Posted by stikpusher on Wednesday, October 7, 2009 3:16 PM
Yes, thin the paint quite a bit. It should be more of a colored thinner than a paint, leaving just the trace of color. Adjust your mixture to suit your taste.
       - Plankton
LSM
    May 2009
Posted by 75th Ranger on Wednesday, October 7, 2009 7:22 PM
is there certain colors that should be used?
    July 2004
Posted by stikpusher on Wednesday, October 7, 2009 7:41 PM
Burnt Umber works great in most circumstances for washes. On sand color subjects another choice is Burnt Sienna. those are good choices for pin washes. On overall washes to tone down and give a dusty/faded look Raw Umber and Raw Sienna are good starting points. Black is too stark in most cases, but does have its uses as well. Mainly for engine areas and such where grime, soot, and oil are most likely to be prevelant. Testors Model Master makes all these colors in both their acrylic and enamel lines.
Experiment and see what you like.
       - Plankton
LSM
    May 2009
Posted by 75th Ranger on Thursday, October 8, 2009 2:16 PM
Thank you very much i'm gonna grab one of my old junk test kits and kive it a shot and see what happens.
Jason
    July 2004
Posted by stikpusher on Thursday, October 8, 2009 2:59 PM
Excellent idea! I suggest using different techniques on different areas to see how they contrast one another.
       - Plankton
LSM
