Drying of tamiya acrylics
    October 2009
Posted by grrr3023 on Thursday, October 22, 2009 2:37 PM
How long does it take for tamiya acrylics to dry and cure? is it permanent or does it scratch? Do i need a topcoat? If so, what kind is recommended?
    August 2006
Posted by HawkeyeHobbies on Thursday, October 22, 2009 3:03 PM
Typically I find that Tamiya acrylics dry to the touch in a matter of minutes. You should allow them to cure for at least 24 hours as acrylics form a glaze, but continue to outgas for some time.
Any paint will scratch, over or topcoat is dependent on what you want or need the paint to do/accept.
Gerald "Hawkeye" Voigt
    August 2005
Posted by Phil_H on Thursday, October 22, 2009 6:25 PM
For Tamiya flat paints, I concur with Gerald. They can be touch dry in minutes, if not seconds when airbrushing but require at least 24 hours to fully cure. When fully cured they are quite tough.
Tamiya Gloss paints can be a different proposition. Because of the "hard" surface film which forms on gloss paints, the solvents can be trapped and can take considerably longer to outgas. Typically, Tamiya gloss paints can be prone to "fingerprinting" for up to 48 hours, and can take a week or more to fully cure. This can vary depending on thickness of application, tenp, humidity etc.
