Typically windshield washer fluids contain chemicals to strip away bugs and road grime. They also have dyes which can affect the paint's final color, especially light colors such as white and yellows.
Typically concentrated means a "stronger" blend* or one that needs to be diluted with water. Regular cheap as you can find windshield washer fluid is suitable for airbrushing. However, you definitely want to use it in a well ventilated area, using the proper respiratory protection and test it on something other than the model you are working on FIRST! I use it on occasion, but not as much as I once did.
Isopropyl alcohol (rubbing) is cheap enough. To stretch it mix it with distilled water. I will use a 70/30 alcohol to water ratio. The water acts as a retarder, as it slows the evaporation/drying process.
*Typically for use at colder temperatures or greater cleaning capacity.
I keep my thinners and cleaners handy. I store them in recycled saline (contact lens solution) bottles. They dispense liquids very nicely and are easily refilled.
From left to right: Lacquer Thinner, Isopropyl Alcohol, Windex, Water, Hawkeye's Thinner, Simple Green and lastly Windshield Washer Fluid.
