cleaning the Paasche VL
Posted by wjbwjb29 on Saturday, October 24, 2009 3:29 PM
Hello;
I have the  paasche Vl and no mater how well I clean it after spraying the next time I go to use it it is locked up and I have to soak it to get the brush to work. When I clean it I spray thinner through it for about a minute. Is there a way to keep the needle from getting stuck. I do dissassemble from time to time to clean but should this have to be done every time I use the brush.
Bill
On the Bench:   Trumperter Tsesarevich on deck Glencoe USS Oregon
    May 2005
Posted by Bgrigg on Saturday, October 24, 2009 4:14 PM
If the needle is continually getting stuck, then you aren't cleaning it as well as you should be. Get yourself some needle lube (AKA Glycerin) and after cleaning, pull the needle and apply a thin coat to the "working" end of the needle. Try not to get any where it gets clamped as it can slip and cause problems.
So long folks!
    October 2008
Posted by Don Wheeler on Saturday, October 24, 2009 5:40 PM
I've had the same experience.  I know that a lot of people just flush the brush and put it away.  But it doesn't work for me.  I have to at least pull the needle and wipe it off or It will sometimes be stuck the next time I go to use it.  And I use lacquer thinner.
Don
https://sites.google.com/site/donsairbrushtips/home
A collection of airbrush tips and reviews
Also an Amazon E-book and paperback of tips.
Posted by MikeV on Saturday, October 24, 2009 7:21 PM
Are you guys back flushing the airbrush? That makes a difference.
    October 2008
Posted by Don Wheeler on Saturday, October 24, 2009 10:28 PM
Yeah, back flushing didn't work for me.  I'm thinking maybe a little paint leaked into the needle bearing, just enough to cause the needle to stick after a day or two.  At any rate, it's so easy to pull the needle and wipe it with a little thinner that I just do it and the problem went away.  I have a different needle bearing now so maybe I should try it again.
Don
Posted by MikeV on Sunday, October 25, 2009 2:32 AM
Don
Don,
What pressure are you spraying at when you clean the AB?
    October 2008
Posted by Don Wheeler on Sunday, October 25, 2009 10:07 AM
 MikeV wrote:
Don,
I usually spray at about 15 or 20psi and I was cleaning at the same pressure.  My little compressor maxes out at about 30psi.  I'll try that next time and see how it goes.
Thanks,
Don
    May 2008
Posted by Boba Fett on Sunday, October 25, 2009 11:09 AM
Every time I clean my VL, I do a total tear-down cleaning. AS long as you take your time, the brush shouldn't clog up. Takes time, but the results are worth it. Especially if you can't afford to buy another brush like me, I'm always terrified I'm gonna wreck the thing with  a big paint clog
Posted by wjbwjb29 on Sunday, October 25, 2009 12:00 PM
Thanks guys, lookes like tacking apart each time is the way to go.
Bill
    November 2008
Posted by mrmike on Thursday, October 29, 2009 2:23 AM
I've had my VL for over twenty years and have enjoyed it's balance and pattern range, but like others have said, it's not an easy gun to maintain. What works for me is to spray the thinner (iso alchohol or laq thinner) thru it until it sprays clear, then pull the needle, wipe clean, reassemble and spray again for 30 seconds to a minute in bursts. This prevents the total teardown and laq thinner cleanups between uses. I am going to try the glycerin wash next time - could be the new trick!
    April 2004
Posted by keilau on Thursday, October 29, 2009 7:45 AM
Mike, I have not tried back flushing a siphon feed airbrush. Does it work as well as on a gravity feed?
Yes, back flushing works wonders if done before the paint has time to dry in the airbrush. If you wait too long, complete disassembly will be called for.
    August 2006
Posted by HawkeyeHobbies on Thursday, October 29, 2009 8:25 AM
My rule of thumb when airbrush cleaning.
I will flush out between colors during a painting session. Once done with the days session (which sometimes can last several hours) I tear down the airbrush as I would my rifle after a day at the range shooting. Tear it down, clean and dry, lube as necessary, reassemble and store it so it is ready for the next session.
"Never enough time to do it right the first time, but always enough time to do it over."  Do it right the first time and you'll find life (painting with an airbrush) is less frustrating.
I will on an occasional bases, tear down and inspect all of my airbrushes to make sure I didn't forget to clean them properly and ensure they'll function properly when I need them most.
When I custom airbrushed T-Shirts, I had five VLs running at once, talk about cleaning time! I got real good at tearing them down. I forgot to clean them once, when I went to use them they were solid...something not good when people are standing and waiting for their shirts to be done.
Gerald "Hawkeye" Voigt
Posted by MikeV on Thursday, October 29, 2009 11:11 PM
Yes it works well for a siphon-feed as well but as you said, if you let paint sit too long in any airbrush it creates problems which is why lubes like Needle Juice are so important in my opinion. A simple spray out with cleaner if you are not going to be painting for 20 minutes or so is always a good idea.
