I have both kinds, and I think what Doc meant was that you typically waste less paint with a gravity fed brush. Water is not paint, paint is by far "stickier" and if you duplicate the experiment with paint you'll find you'll use more with the siphon.
Let's say I'm using my trusty old siphon fed Badger 150 with the color cup. I have to put enough paint in the cup to cover the siphon tube. After spraying, I am left with whatever paint remains in the color cup, paint in the cup's siphon tube, and the paint in the 150's siphon tube out to the tip of the AB.
If I use my gravity fed 100LG (which has the exact same needle and nozzle as the 150 BTW) I can put less paint in the cup to begin with as I'm not concerned with creating suction. After spraying, I am left with whatever paint stuck to the cup, and the short distance from the cup to the tip.
We're not talking about a lot of paint, but there is a small saving in both paint and cleanup time. Not enough to sway my purchase from one to the other, but if I'm going to be spraying only a small amount of a color, the 100 is the one I pull out to use.
The difference is line size is effectively nil, at least in my hands!
