Room Temperature for Airbrush Spraying
    May 2006
Posted by Shipwreck on Thursday, October 29, 2009 6:26 AM
Winter is coming for many of us! I will probably have to do most of my airbrush work in a cold garage in a temperature range of 35 to 45 degrees. Would this work? What would be an acceptable range?
Thank you.
On the Bench:
Revell 1/96 USS Constitution - rigging
Revell 1/48 B-1B Lancer Prep and research
Trumpeter 1/350 USS Hornet CV-8 Prep and research
    August 2006
Posted by HawkeyeHobbies on Thursday, October 29, 2009 8:12 AM
If there is any way to create yourself an area/room that can be warmed up to at least 50 degrees you'd be better off. Use some tarps to make a tent that you can warm with a small space heater. If you can't keep your paint and model in the warmth of the house to the last possible moment. The other factor of the process is the compressor itself. Being in a cold damp room it will be pumping out cold damp air. This can be an issue. Here's where a CO2 setup excels.
What is the reason you can't spray indoors? Odor? SWMBO?
Gerald "Hawkeye" Voigt
Posted by MikeV on Thursday, October 29, 2009 11:13 PM
Warm the paint indoors and then go out in the garage and paint and bring it back indoors somewhere to cure. I have done that and with flat paints it wasn't a problem. With gloss colors I wouldn't recommend it though.
    December 2003
Posted by 9x19mm on Monday, November 2, 2009 12:57 AM
Get a candle melter or coffee cup warmer. Either should help, plug it in out where your painting and use it to warm the paint.   The paint should be a better spraying temp.  I paid less then 10 for mine.
Posted by MikeV on Monday, November 2, 2009 10:35 PM
I used to just put the bottle of paint and the airbrush under a 100 watt lightbulb for a while and then paint when I used to paint in the cold garage. You could also use a hair dryer.
