Ok to use differant brands of paint on model
    October 2009
Posted by Khalee2 on Tuesday, November 3, 2009 8:55 PM
I have allways been a testors mm user when I was active in the past, as that was all the local stores carried, but since I am getting back into it and ordering from the net I am wondering is there any special precaution on useing  model master with humbrol paints and tamiya paints together. I do know you can't use enamel and acrilic together but other than that what else does one need to know.
    August 2005
Posted by Phil_H on Tuesday, November 3, 2009 11:03 PM
Are you talking about mixing paints or applying one type/brand over another?
When mixing paints, preferably, stick to paints of the same manufacturer. You can't mix acrylics and enamels.
If overpainting, you should be able to overpaint any brand of paint with any other (though one should try to avoid overpainting enamels/acrylics with lacquers if at all possible)  You can overpaint enamels with acrylics (and vice versa) as long as the layer being overpainted is fully cured (at least 24 hours)
    October 2009
Posted by Khalee2 on Wednesday, November 4, 2009 1:16 AM
Yes Im just talking about overpainting,not mixing. And I did not know about the other one as I've allways heard you could not paint enamels and acrylics over each other as bad things would happen. But that is good to know. Thanks.
    April 2004
Posted by keilau on Wednesday, November 4, 2009 6:41 AM
If you airbrush paints, watch out for the thinner you use. I have had MM acrylic gum up with other brand of thinner. When you switch paint on the same airbrush, it must be thoroughly dry before the next color.
Posted by MikeV on Wednesday, November 4, 2009 11:50 AM
Any paint can be sprayed over another if done correctly but many people don't know the tricks so it is best to put the "hottest" paints like lacquers on first.
Many people spray Testors Dull Coat over enamel finishes and Dull Coat is lacquer based. Wink [;)]
Posted by ajlafleche on Wednesday, November 4, 2009 2:56 PM
And I routinely airbrush Testor's Dullcoat thinned with DIY store generic "paint thinner" over acrylics with no problems. I apply, when needed, oil washes thinned with the same thinner over enamels and/or acrylics with no problems. I don't scrub my washes, however. Bottom line, in 30+ years experience, once a paint is fully cured, you can do almost anything to it.
    May 2005
Posted by Bgrigg on Wednesday, November 4, 2009 3:56 PM
Al is perfectly correct that any paint can be overpainted with another once it is fully CURED.
Just to clarify, dry to the touch is not an indication of cured, as only the surface is dry. Some paints may take a month to be fully cured. It is always a good idea to keep a closet queen on hand to test before commiting yourself.
So long folks!
    May 2003
Posted by qmiester on Sunday, November 8, 2009 8:58 AM
One trick to determine if the paint has completly cured is to simply sniff it.  If it has a faint "paint" smell, it still hasn't cured completly.  In that case, simply wait another day and sniff again - Been working for model railroaders for years
Quincy
