Air pressure settings
    January 2009
Posted by psufan74 on Friday, November 6, 2009 8:56 PM
Hello,
 I am still trying to learn all about airbrushing. Having pretty good luck so far but was wondering what air pressure setting works best for larger pieces such as airplane fuslages and armor pieces. I usually spray at 15-20 psi but sometimes i get shiny spots. Does this come from too high a setting?
    April 2004
Posted by keilau on Friday, November 6, 2009 9:38 PM
There is no "one size fits all" pressure setting. It depends on the airbrush you use and the type and consistance of paint that you use.
You can find many posts on this topic if you do a search on this forum.
    July 2009
Posted by COLDIRON on Friday, November 6, 2009 11:51 PM
shiny spots could be from either trying to apply too much paint at one time or not moving the airbrush fast enough.  15-20 PSI is right around where you want to be.  I usually paint at about 15 PSI for a gravity feed and 20-30 for a bottom feed airbrush.
    January 2009
Posted by psufan74 on Saturday, November 7, 2009 1:48 PM
I use a badger 200. I usually spray between 10-20 psi.  Could the shiny spots be from applying too much paint at one time. I think i might put too much at once. Need to learn more patience  probably!  Thanks for the replies.
    July 2009
Posted by COLDIRON on Sunday, November 8, 2009 1:07 AM
Gravity or bottom feed 200?  If you have a bottom feed I would use at least 20 PSI.  Gravity around 15 is good.
