kbuzz01 wrote: |
I would like a unit that can perform uses other than airbrushing, and am considering a couple of Craftsman (Sears) 125 PSI compressors, providing about 3 SCFM @ 40 PSI. |
No sure what you other uses are. "3 SCFM @ 40 PSI" is good for inflating auto tires, but may be too low a pressure for most other household jobs. (Unless you don't mind waiting a few seconds inbetween each nail or staple when using an air gun.) Sears has several compressors with 1-HP oiled motor that can provide 2.4 SCFM @ 90 PSI for less than $200. I got mine for $100 at one of their sales. They are more practical for small re-modeling works around the house.
Don't buy any cheap brand oilless compressor such as those sold at Walmart. They are too noisy for airbrush and have too little power for other practical uses.
My primary question is - what are the pros and cons of oil-lube vs oil-less units regarding their use in airbrushing? (I do understand that I will need accessories such as filters, water traps, etc.) Additionally, are there any inherent reliability problems between the two types? It will be used in a garage and/or outdoor environment. |
I tried a Dewalt 55140 oilless compressor once. It did everything well for airbrushing and have enough air for half a dozen airbrushs. It is even quiet enough that I can put it in the next room when I airbrushed and was not bothered by the noise. But the 0.6 SCFM is not very convenient for other uses. When I looked at oilless compressor that have enough power for household works, I found several by Dewalt, Maxus and Senco. But the price tab of $300 is too much for occasional use. I settled for an Paasche DA400 compressor for airbrush and a Sears oiled compressor for household uses. Total is almost $300 for both, but I like the convenience of this arrangement.
I don't feel comfortable using an oiled compressor for airbrushing and never tried it. I will let others who does to offer their put to such use.
