Alclad Paint question
    April 2009
Posted by Cadet Chuck on Tuesday, November 17, 2009 10:04 PM
Having heard great praises for Alclad metallic paints, I tried for the first time to use them and ruined my aircraft model at the first step.  I sprayed the black primer of theirs and it mottled and wrinkled up the plastic and will not dry!
Perhaps my mistake was first polishing the bare plastic with Novus #2 polish.
What a bummer!  Should I have simply washed the model with dishwashing detergent first, and not polished it?  Any words of wisdom, please?
    June 2009
Posted by jimbot58 on Wednesday, November 18, 2009 1:56 AM
Their primer may have been too "hot" for the plastic of your particular kit. Some use other brands of gloss black as a primer/base. The Alclad is a lacquer base-very bad for plastic. I don't know if others can suggest a better way of using it. I have some of the alclad but have yet to try it.
On my workbench now:
It's all about classic cars now!
Why can't I find the "Any" key on my keyboard?
    April 2005
Posted by wing_nut on Wednesday, November 18, 2009 7:11 AM
There was a period when the Alclad black was bad.  Lots of people with the same complaint as you.  Then the stories started getting better and it was chalked up to a bad batch a while ago.  You may have gotten one of those.  I use Model Master gloss back enamel and let it cure for about a week.
This brings up an important point.  Unless you are using Alclad chrome or polished aluminum, you do not need the black under coat. As far as polishing, yes that is a good idea.  Any minor scratch will stand out like a sore thumb from the Alclad.
Here is the technique I used that I got from a webinar given by master molder Floyd Werner.  Sand all the seams etc. and get the model prepped as best you can.  A primer coat of Mr. Surfacer 1200 is applied and allowed to cure.  This is also a lacquer but goes down smooth and will protect the plastic from the hot Alclad.  The Mr. S is polished with 6000 micromesh.  Believe it or not, a clean coffee filter works pretty well too.  Make sure you have a good clean surface then apply the Alclad.
Get a couple of really cheap models and just build the airframes to practice.  It is way easier than all of what I just said sounds.
Marc
    April 2009
Posted by Cadet Chuck on Wednesday, November 18, 2009 10:17 AM
Thanks, guys, that all makes sense.  Fortunately this was a simple and inexpensive model that I did not invest a lot of time in building, as I considered this project to be an experiment with using Alclad.  I have seen some really beautiful finishes with it.  But I don't think I'll risk using it again.
Excellent work on those models, Wing-Nut.  That's what I was hoping to achieve....Sign - Oops [#oops]
    April 2005
Posted by wing_nut on Wednesday, November 18, 2009 10:31 PM
Thanks Chuck. Oh and you can be sure... you are not looking at my 1st attempt eitherWink [;)]
Marc
