Tamiya flat base
    May 2003
Tamiya flat base
Posted by Robert92562 on Wednesday, November 18, 2009 5:32 PM
Has anyone used Tamiya's flat base X-21? How does it dry. In the jar it look simi-transparent. Will it dry clear.
thanks
    August 2005
Posted by Phil_H on Wednesday, November 18, 2009 5:57 PM
Robert.
Tamiya X-21 Flat Base is not a flat clearcoat. It is an additive  which is used to make gloss colours (including X-22 Clear) flat.
BE WARNED: DO NOT use it on its own. Doing so will result in a model covered in sticky translucent white goo.
To make a flat clear using this product, mix it with X-22 Clear (or Future) in a ratio of about 4 parts clear to one part Flat Base.
    May 2005
Posted by Bgrigg on Wednesday, November 18, 2009 7:28 PM
You can also mix it with Future to achieve various levels of flatness.
So long folks!
    April 2004
Posted by keilau on Thursday, November 19, 2009 12:34 PM
thanks
The answer is in this post.
The X-21 is an additive, not to be used by itself.
Posted by ajlafleche on Thursday, November 19, 2009 2:56 PM
The best formula for successfully using flat base is the following:
Add four parts Flat Base and
Round about the Cauldron go;
In the poison'd Entrails throw.
Toad, that under cold stone
Days and Nights has thirty-one
Swelter'd Venom sleeping got,
Boil thou first i' the charmed pot.
Double, double toile and trouble ;
Fire burn and Cauldron bubble.
Fillet of a Fenny Snake,
In the Cauldron boil and bake;
Eye of Newt, and Toe of Frogge,
Wool of Bat, and Tongue of Dogge,
Adder's Fork, and Blind-worm's Sting,
Lizard's leg, and Howlet's wing,
For a Charm of powerful trouble
Like a Hell-broth boil and bubble.
Double, double toyle and trouble,
Scale of Dragon, Tooth of Wolf,
Witches' Mummy, Maw and Gulf
Of the ravin'd salt Sea shark,
Root of Hemlock digg'd i' the dark,
Liver of Blaspheming Jew,
Gall of Goat, and Slips of Yew
Silver'd in the Moon's Eclipse,
Nose of Turk, and Tartar's lips,
Finger of Birth-strangled Babe
Ditch-deliver'd by a Drab,
Make the Gruel thick and slab:
Add thereto a Tiger's Chaudron,
For the Ingredients of our Cauldron.
Cool it with a Baboon's blood,
Then the Charm is firm and good.
O! well done! I commend your pains,
And every one shall share i' the gains.
And now about the Cauldron sing,
Like Elves and Fairies in a Ring,
Enchanting all that you put in.
Black spirits and white, red spirits and gray;
Mingle, mingle, mingle, you that mingle may.
    May 2003
Posted by Robert92562 on Friday, November 20, 2009 2:03 PM
that helps
to the others... thanks
    May 2005
Posted by Bgrigg on Friday, November 20, 2009 3:54 PM
I thought it was toe of newt and eye of frog? Love the MacBeth quote!
So long folks!
