Need some help with oils, please.
Posted by oortiz10 on Tuesday, November 24, 2009 12:25 PM
Hey gang,
I've been seeing the effects oils have on the realism of figure painting and when weathering kits. I'd like to give 'em a try. Figured since Xmas was coming up, I could add some to my list. Does anyone have any suggestions? Since this will be my first attempt with 'em, I could use some input on a manufacturer. Maybe some help on a thinner to use too. I'm looking for a small set, maybe one with just a few of the basic colors. (Did a quick search and found these as a set.) Like I said, I'm totally new at this and looking to start, so I could really use the basics when it comes to this stuff.
Please, if anyone out there could share their expertise, I'd greatly appreciate it.
Thanks!
-O
-It's Omar, but they call me "O".
    July 2003
Posted by zokissima on Thursday, November 26, 2009 12:26 PM
Any mineral spirit thinner will work.
As for the manufacturer, just go to an art supply store, and anything you find will be fine, so just look for whatever the cheaper option you can get is.
Colours, you wish to get at least all of the primary colours, plus white, black, raw umber, burnt umber, sepia, orchre, yellow ochre, etc.
    November 2008
Posted by plasticjunkie on Wednesday, December 2, 2009 11:27 AM
If you have a Hobby Lobby in your area, go to their web page and check when the 40% coupon is available, usually once a month for like a week or so. I picked up a Reeve's 24 tube set for $6 or $7  a while back. I can mix custom colors and it really gives you a greater color range for detailing with washes and filtering. I use regular paint thinner from Walmart. It works great!
 GIFMaker.org_jy_Ayj_O
Posted by rjkplasticmod on Wednesday, December 2, 2009 12:33 PM
For weathering, any brand of oil will do, but for figure painting I highly recommend Winsor & Newton.  These are a little more expensive, but have the finest pigments available.  For thinning, Mineral Spirits or oderless Turpenoid is what I use.  You can find these products at most Craft Stores.  I get mine at the local Michaels.
Regards,  Rick
    August 2005
Posted by EdGrune on Wednesday, December 2, 2009 2:44 PM
Roger that on the Turpenoid.
Turpenoid is a more highly refined turpentine and works well with oil paints.  Most mineral spirits and/or turpentine (white spirits/turps) from the hardware store seems to be a little 'hotter' than Turpenoid and may affect the underlying paints in variable unpredictable manners.
