- Member since
April 2008
Posted by *INDY
on Friday, December 4, 2009 1:51 AM
ajlafleche wrote: | Repeating myself: Quite frankly, thinner is thinner. If you want to spend over four hundred dollars a gallon for "Airbrush" thinner from a model paint manufacturer, knock yourself out. I've used gallon cans (under $10 a gallon) of Ace Hardware "Paint Thinner" for Model Master Enamels, Floquil paints, Testors' Dullcoat and Glosscote, Humbrol enamels, Testor's little square bottle enamels and tube oils for decades with no problems at all. I keep some for cleaning brushes until it gets nasty and some clean one to thin paints or run through the airbrush. For my Vallejo paints, I use distilled water from the local CVS as recommended by the manufacturer. If a paint requires a proprietary thinner, the manufacturer has done this for one reason: to separate you from as much of your money as possible as quickly as possible. |
AL is dead on target here. I completely agree, no matter what someone tries to get you to buy....if you say you notice a difference....it's your money. I never stoppped to calculate if I was saving $400 or $800 a gallon but I knew it was quite alot. Besides WATER for artist's and Vallejo acrylics, I use cheap rubbing alcohol(under $3 a quart in any drugstore) for Tamiya paints(the Tamiya thinner BOTTLE works perfect on the bench) And for my testors Enamels, Floquil, and artist's oil paints, cheap($4 at Walmart) white spirit(paint thinner) and the testors thinner BOTTLE works perfect for that. I have some laquer thinner, and I get it out when I need it only!(as it's very caustic, toxic and dangerous)for use with Alclad, Tamiya Liquid Surface primer and any job the regular thinner WON'T do, which isn't that many. Why chemical over-kill on your bench>? Why spend for namebrand thinner and pay shipping and wait when the corner store has a way better deal?
"Well...you gunna pull them pistols, or just whistle Dixie?"
