Humbrol acrylic thinning issue?
    October 2007
Posted by Milairjunkie on Wednesday, December 9, 2009 3:15 PM
I have just tried to use Humbrol acrylic for the first time (noramly use Tamiya), thinned with water @ a ratio of 3-2 (paint to water) & have a problem.
The paint consistency looks OK (just possibly on the thin side), but my airbrush (Infnity) is not happy with it, I will get an initial flow of paint on pulling the trigger, but then the flow quickly reduces to next to nothing. I have cleaned the brush out, checked its operation with water (all OK) & tried again with a fresh 3-2 mix - but have exactly the same issue.
Any advice would be appreciated.
    October 2007
Posted by Milairjunkie on Thursday, December 10, 2009 12:27 PM
I have now tried the Humbrol acrylic with Tamiya thinners in ratios from 3-2 to 1-1 & I still have the same problem. I did find things slightly more workable by bumping my compressor output to 30psi (which is twice what I usualy use in my gravity brush with Tamiya). The paint looks clean & consistent & is pretty new.
Help, I'm stumped.
    November 2008
Posted by plasticjunkie on Saturday, December 19, 2009 9:13 PM
Could it be possible that the paint is still not thin enough to cycle thru the AB? I think that if you needed to increase ap then the paint may still be a bit thick.
 GIFMaker.org_jy_Ayj_O
    October 2007
Posted by Milairjunkie on Monday, December 21, 2009 4:27 AM
When I tried the stuff at 50/50 with Tamiya thinners or water, the paint gave very poor coverage - you know when it gets that thin you can almost see the pigment floating around in the carrier when it lands? I had assumed at that point adding any further thinner would just cause more problems & result in umpteen coats being needed.
Have you used Humbrol Acrylics?
    November 2008
Posted by plasticjunkie on Monday, December 21, 2009 11:16 AM
I've haven't used their acrylics but I've used their enamels in the small tin cans for years and they are my favorite enamels, specially for brushing. I have used the Tamiya, Polly Scale  and MM Acryl paints without  any problems. I cut them with either alcohol or distilled water with a drop dishwashing liquid soap, but they have to be extra thinned for airbrush use, otherwise I get a lot of spitting and grainy texture..
