Just the same way they paint real 1:1 cars to get the depth and shine. It depends on the surface, the paint, the application, equipment and mostly the person skill at doing it all.
Be sure that your thinner is compatible with your paint. Some thinners will de-gloss a glossy paint. You want one that will allow the paint to retain its leveling and gloss properties once applied.
You may want to start with a light cover coat of the color being applied, again as a hot rod painter would, rub out the paint before continuing onto the next. Hand rubbed paint jobs always seem to be the best.
Instead of a clear, you might want to apply car wax.
Let the paint cure for several days before applying anything over the paint!
