Stripping Resin?
    May 2009
Stripping Resin?
Posted by Konigwolf13 on Sunday, December 13, 2009 3:05 AM
What is safe to use for stripping enamel off resin?
Andrew
    August 2005
Posted by EdGrune on Monday, December 14, 2009 6:26 AM
Easy-off oven cleaner.   Put the resin parts in a large plastic or glass container, preferably one with a cover.    Spray the oven cleaner over the part getting good coverage.   Close the top and give it several hours to overnight to work.   Later remove and brush with an old toothbrush,   rinse and allow to dry.    Repeat as necessary.    Typical eye and skin cautions apply.
Others may recommend Simple Green cleaner.   Never used it having found success with the oven cleaner.
    June 2006
Posted by The Mad Klingon on Monday, December 14, 2009 7:19 AM
Castrol Super Clean (Big Purple Jug)  works wonders. But note, it will chew up any putty used on the model as well. Stubborn paint can be removed with a toothbrush.
    July 2003
Posted by zokissima on Monday, December 14, 2009 2:38 PM
+1 to the Easy-Off oven cleaner. It works wonders. Follow the advice given, place the parts/figures in a plastic jar of some kind, soak with the cleaner, and the next day go to town with a toothbrush. Most of the paint will come off in the first swipe.
    May 2009
Posted by Konigwolf13 on Monday, December 14, 2009 8:31 PM
+1 for the Mr. Muscle (non-caustic) oven cleaner, what we have in oz.
Left it overnight, no problemo. I use on plastics for enamels I didnt know if it was safe on resin, thanks peeps.
Andrew
