I just picked up a Supermarine Spitfire and was looking at the colors and seeing how I can't get a hold of Humbrol products I was thinking about us OD Green and a l White. Any suggestions or should this work.
Wes
Hi Wes,
If the "beige green" you're looking for is for the underside of the Spitfire, then you're looking for RAF "Sky Type-S" - Model Master has it as #2049. In Tamiya it would be XF-21.
Okie Dokie, that helps but I thought I was talking about the Cockpit color. Thought I was right on. That's what I get for thinking right. I hope I'm not color blind wouldn't be good in my job.
Hey Wes,
If you're looking at the cockpit colour, it would be RAF Interior Green, Model Master #2062
Tamiya don't have this "out of the bottle", the nearest would be (IJN) Cockpit green, XF-71, or a mix of XF-5 Flat Green with XF-2 Flat White
Thank you so much!!!!!!
