The face area of your booth works out to 4.4 square feet. Unless you are building a booth in a down-draft configuration, the MINIMUM fan rating should be 350 cfm. You should opt for one that will give you 100 fpm face velocity, which would be a fan rated at about 450 cfm.
Happy New Year!
Gip
