Need Help
    January 2010
Need Help
Posted by JA8171 on Thursday, January 7, 2010 6:03 PM
Hello everyone I have been modeling my whole life but I never painted my models I would just build them put on the decals and call it a job well done, but know I would like to start painting them can anyone help me with airbrushes and what I should start with.
    October 2007
Posted by Milairjunkie on Friday, January 8, 2010 3:55 AM
The question is very dependant on how much you are prepared to invest, you could get a cheap Chinese clone/copy airbrush & diaghpram compressor for a very reasonable amount. However if you are prepared to invest a little bit you would probably be better with a reputable brand airbrush (Badger, Iwata, Paasche, H&S.....) & a small piston compressor (hobby size, not garage) that includes a regulator & water trap.
For what its worth, I would advise a double action gravity fed brush with a mid size needle / nozzle combination. Several manufacturers provide additional alternative needle / nozzle combinations, smaller ones for fine detail & larger ones for large coverage, these can be purchased "after the fact". Airbrushes are a bit like watches, they are precision instruments which take pride of place amongst the hobby tools & everyone has strong opinions on which is the better model - bottom line is that reputable brushes these day, as long as matched to your use are all good.
I returned to the hobby a couple of years ago & decided this time around to get an airbrush, although the whole set up cost a few pounds, it is without doubt the best hobby related investment I have ever made
    January 2010
Posted by JA8171 on Friday, January 8, 2010 7:38 AM
Thank you so much for your reply it was very helpful, wish the best in your future modeling endevors
Posted by Don Stauffer on Friday, January 8, 2010 9:13 AM
I consider the compressor almost a more important choice than the airbrush itself.  There are some very expensive compressors that are very good yet quiet.  I used to use a big compressor/tank unit in the garage with air piped down into my shop.  Okay for warm climates- not here in Minnesota.  Unit will not start in below zero weather.
Recently I bought a small portable compressor with one gallon tank from local building supply store, on sale for fifty bucks.  Has a regulator on it, a must-have feature.  Others are available in range of sixty to eighty bucks.  Only downside is noise.  I had some old headphones, the big ones that completely cover the ear.  Now when I am ready to airbrush I plug those into workshop radio-cuts the noise down very well Smile    I am now spraying in coldest weather!
My main brush is a Badger 200 SA one, but also have an Aztek DA and a cheap Badger DA knockoff.
    May 2005
Posted by Bgrigg on Friday, January 8, 2010 11:40 AM
I concur that the dual action gravity fed internal mix airbrush with a medium needle is the most versatile airbrush. I own single action siphon fed, dual action siphon fed and dual action gravity fed airbrushes, and it's the latter that I pull out of the holster most. Easy to use, easy to clean and slightly less wasteful of paint (no siphon tube to clean). My personal choice is Badger (200-20, 150 & 100LG), but most of the "brand" name airbrushes are excellent tools.
Given your location give Bear Air a call. Their located in S. Easton MA, a short drive away if my geography is correct. I'm not sure if they have a store front, but if they do it would be worth your time to visit to handle the different kinds of airbrushes they offer.
A decent starter combo compressor/airbrush is their Polar Bear 1000 & Peak C-3 for $125 + S&H (you might be able to save on the S&H part!). Recently a fellow FSMer (Zokissima) bought their Polar Bear 2000 & Peak C-5 for $219 + S&H, and has expressed satisfaction with his purchase. You would have to buy an airhose (around $10), but they do come with regulator and moisture trap, both very important for successful airbrushing!
There are better compressors and airbrushes out there, but I'm loathe to suggest a beginner to buy a $250 airbrush and $500 compressor.
So long folks!
    January 2010
Posted by JA8171 on Friday, January 8, 2010 12:02 PM
thank you Bgrigg I know exactly where they are about 20 min. from my house I just called them and i am going there today after work.
    May 2005
Posted by Bgrigg on Friday, January 8, 2010 12:11 PM
And there you go! My geography doesn't suck! Big Smile
So long folks!
    October 2007
Posted by Milairjunkie on Friday, January 8, 2010 1:08 PM
Good one man, get into it, you won't regret it!
Posted by rjkplasticmod on Friday, January 8, 2010 1:45 PM
I've owned several AB's over the years, but my Go-To for the last few years is the Badger 100LG with medium tip.  But I agree that the compressor is very important.  Whatever Brand you get, be sure it has a built in  air supply  tank.
Regards,  Rick
