Brush painting details in a jet cockpit (Or any aircraft for that matter)
    December 2014
Posted by Ffowcs on Monday, February 8, 2010 5:12 PM
I'm in the process of painting the 'office' of a 1/32nd scale F-104, and although it is a big model there are more finer details to paint in the cockpit than there are in a smaller scale version. The nearest I've been to this before is when I modeled Revell's 1/32nd Hawker Hunter and I was pleased with the job I did on painting that model's cockpit, but oh boy did it take a lot of effort to finish brush painting every switch and dial. Even though I have a fairly steady hand I kept getting paint on places I didn't want to, for example whilst painting the dials black I got paint on the grey consoles. To avoid this, is dry brushing one way of doing it? I do have fine brushes, but maybe I should invest in having a magnifying glass on a stand as well. Yeh, so to anyone who reads this perhaps you'd like to share please some hints and tips on how to paint the details in a jet cockpit.
    August 2006
Posted by HawkeyeHobbies on Monday, February 8, 2010 5:18 PM
For small knobs and such details try using technical pens with various colored inks. Or source out a good decal sheet. Some of the knobs and switched found in scale model cockpits would scale up to the size of  a door knob, not one found on an instrument panel.
Gerald "Hawkeye" Voigt
Posted by Don Stauffer on Tuesday, February 9, 2010 9:35 AM
For really small detail I use a toothpick instead of a brush.  Use the circular cross-section type that come to a sharp point at each end.
Now, shake the paint thoroughly, take the cap off and place the cap upside down on bench.  Some paint should be adhering to the cap.  This layer is just the right thickness to dip the toothpick in.  Dip the end of the toothpick and apply paint to model.  after awhile you will have used up paint in cap, so you need to put it back on jar and reshake.  If the area is a thin line rather than a spot, I make an overlapping dotted line.  Do not draw point along like a brush, do the painting like the punctillist impressionistic painters- lots of dots.  Just press tip of pick straight against surface.  Great for warning lights and stuff, but you can build up dials and stuff with a series of overlapping dots.
    December 2014
Posted by Ffowcs on Tuesday, February 9, 2010 2:49 PM
Thank you to Hawkeye and Don Stauffer for your replies. Yes, I'll try those techniques - the technical pens and the toothpick. Also, in the not too distant future I'll try and load pics of how my work is progressing.
    September 2007
Posted by SuppressionFire on Tuesday, February 9, 2010 3:02 PM
'Now, shake the paint thoroughly, take the cap off and place the cap upside down on bench.  Some paint should be adhering to the cap.  This layer is just the right thickness to dip the toothpick in.  Dip the end of the toothpick and apply paint to model.  after awhile you will have used up paint in cap, so you need to put it back on jar and reshake.  If the area is a thin line rather than a spot, I make an overlapping dotted line.  Do not draw point along like a brush, do the painting like the punctillist impressionistic painters- lots of dots.  Just press tip of pick straight against surface.  Great for warning lights and stuff, but you can build up dials and stuff with a series of overlapping dots.'
Agreed with that technique. I do disagree with shakeing paint bottles and the upside down idea. Get a stainless pin to stir the paint and get the bottem thick stuff that way. What he means is you need the pigments at the bottem for details. Think in dots and if opaque make another pass once dry.
Paint in the lid is going to cause grief next time you open the jar. Always remove a dab and put on clean glass to use from. While jar is open mix and add thinner if its getting to thick, whipe lid and threads before sealing jar for storage.
 I used tooth pick method after brush gave grief on the side wall. Paint bigger dials and leavers, use dots for touch-ups and tiny switches.
http://i6.photobucket.com/albums/y211/razordws/GB%20Badges/WMIIIGBsmall.jpg
