primers
    January 2013
primers
Posted by Armyguy on Friday, March 29, 2013 4:24 PM
This may have been asked before but in searching the forum I can't  seem to find the answer .
 What is the trick to using Model Master gray and white acrylic primers. I generally  use Polly Scale zinc chrome primer with no problems.
 In searching the forum other primers were mentioned so I have a few new things to think about.
    March 2005
Posted by TarnShip on Friday, March 29, 2013 5:16 PM
the quickest trick to using the MM Acrylic primers is to add some Future to your mix,,,,,,,or try some Golden Medium, # GAC 200
another way is to give your model a coat of straight Future, sand it with steel wool (to scratch it up), wash it clean, then spray a thin coat of MM primer over that
I just did a side by side by side test with MM primer over Future coat, MM+Future mix, and MM + Golden,,,,,,,,all three stood up to the "burnished Blue tape" rip off adhesion test
I still like the Vallejo large bottle gray primer mixed with Golden 200 better, though
Rex
almost gone
    January 2013
Posted by Armyguy on Friday, March 29, 2013 7:51 PM
    Rex    Thanks for the tips. Tried thinning with alcohol that seemed to help some.
Will try mixing Future and when I get to the hobby I'll look for Vallejo gray primer.
Thanks again Dave
    February 2011
Posted by Hokey on Saturday, March 30, 2013 7:46 AM
Is there a problem using the MM primers rite out of the can?
    April 2006
Posted by waynec on Saturday, March 30, 2013 2:27 PM
i go to ace hardware and use the NOW cans at < $3.00US  for a big can. us eit to check seams and as a primer for acrylics. have had no problems until i get near the bottom and it gets a tad powdery. just shake it well and use that part of the can for armor. crack a new can for boats and planes.
Никто не Забыт    (No one is Forgotten)
Ничто не Забыто  (Nothing is Forgotten)
    March 2005
Posted by TarnShip on Saturday, March 30, 2013 3:08 PM
MM doesn't make an Acrylic Primer in a spray can, that I am aware of,,,,,,,,,,,and some of us are locked into "all real Acrylic paints"
are the Ace NOW primers an Acrylic?,,,,,,,,,if so, I need to give them a try
Rex
*note, for modeling purposes with a health challenged person in the house, "real" Acrylics means no Lacquer or Enamel fumes or chemicals
almost gone
    January 2013
Posted by Armyguy on Saturday, March 30, 2013 4:25 PM
Hokey  the times I tried  M M white and gray  primers  they just did not cover right. Did every thing as usual washed the model and stirred the primers.
Tarn Ship again thanks for the pointers,and  I do use total acrylics switched years ago  keeps the wife quiet about the smell and I can paint when I want don't have to worry if the grandkids are coming over.
  Dave
    March 2005
Posted by TarnShip on Saturday, March 30, 2013 5:28 PM
one thing about Vallejo that I always forget to add,,,,,,,,there is a "primer" color in their little bottles,,,,,,,that is a paint that is the color of primer, maybe something to use when painting a body panel on an old half finished Hot Rod car
the real primers are in larger bottles,,,,,and come in many colors
here is the one I use
www.megahobby.com/200mlbottlegreyprimervallejopaint.aspx
you can find it cheaper by shopping around, I just grabbed the first link with an expandable image for you
Rex
almost gone
