I built Don's Drying Booth
    October 2013
Posted by infofrog on Saturday, October 24, 2015 4:09 PM
This is a thank you for sharing your ideal of drying booth
I'm not sure if this goes here or needs moved. If so thank you .
I used maple wood plywood in stock in the garage .
Pick up light bulb switch , 60 watt bulb , handy box and dimmer switch .
Tools
Saw and jig
clamps
Kreg jig
wood glue
Enjoy
Rick
I cut the plywood to size .
Then used kreg jig to screw the panels together . The panels parts , I did add wood glue before screwing them together
The one side , I sloted out for inlet air in to box
I install light bulb switch , handy box
    October 2013
Posted by infofrog on Saturday, October 24, 2015 4:13 PM
I built the top to rest on inner supports
Now I drilled holes in top to allow heat to enter top area. Then applied satin clear
Now back to main body . I applied flat black
    October 2013
Posted by infofrog on Saturday, October 24, 2015 4:14 PM
Here is the final dry booth
    October 2013
Posted by infofrog on Saturday, October 24, 2015 4:15 PM
Now I'm in test mode . Temps. test
I will post more tomorrow on how it heats
Rick
    September 2012
Posted by GMorrison on Saturday, October 24, 2015 4:25 PM
You made this with a handheld circular saw?
Bow DownBow DownBow Down
    October 2013
Posted by infofrog on Saturday, October 24, 2015 4:39 PM
GMorrison
Yes , with the homemade straight edge jig .
. I have   wood working shop , will in my garage that is .
But for this simple job Yes that is all I used . The kreg joint is nice for project like this .
Rick
    August 2007
Posted by DUSTER on Saturday, October 24, 2015 7:21 PM
Beautiful job Rick. Looks like a store bought unit.
Just noticed in the pictures you hadn't yet cut the top of the plastic box for its vent. But you  probably already got that.
Steve
Posted by Texgunner on Sunday, October 25, 2015 9:22 AM
Man, you did a beautiful job on that!  Great skills brother!.Yes
Gary
"All you mugs need to get busy building, and post pics!"
    October 2013
Posted by infofrog on Sunday, October 25, 2015 10:40 AM
Texgunner
Gary
Thanks . this was was with basic tools . Anyone can do it
After Three hours on heat time . My temps max out top part of the plastic cases   87 , the bottom 90 . Room temp 72 .
I'm not sure what temps are ideal for scale modeling , but I don't these temps are bad .
Enjoy
Rick
Posted by Don Stauffer on Sunday, October 25, 2015 11:20 AM
I'd go a bit higher in temp.  My booth runs at 105 in center of chamber.  I have restricted the temp 'cause I know folks who tried to use food dehydrators which warped their models.  I'd try a 75 watt bulb.  My box has a light dimming switch instead of a simple switch.  But then found I could run the switch wide open with the sixty watt bulb, so don't need the dimmer.  If a test shows a 75 watt bulb too hot, add the dimmer, but my guess is the 75 watt will be okay. I don't think I'd want more than about 140 degrees- just a guess.
    October 2013
Posted by infofrog on Sunday, October 25, 2015 1:43 PM
Thank you Rick
    July 2014
Posted by Bakster on Wednesday, November 4, 2015 6:33 PM
Nice job Rick.  Might have to build one.
Steve
    October 2013
Posted by infofrog on Wednesday, November 4, 2015 6:56 PM
Works great . I have it holding at 91 . I dont want any hotter . Scared of issues . But I'm very happy .. i would build another in a heart beat . Rick
