Which portable compressor?
    August 2019
Posted by HighDesertmodeler on Saturday, August 31, 2019 6:21 PM
looking for any recommendations regarding a portable compressor.  I typically spray from 5 psi to 20-25 psi depending upon the application.
Thank you
Posted by Don Stauffer on Sunday, September 1, 2019 6:49 AM
HighDesertmodeler
Thank you
What is your criteria for portable?  Do you need battery or powerless spraying?  Or just light weight?
    August 2019
Posted by HighDesertmodeler on Sunday, September 1, 2019 10:34 PM
Thank you Don, I’m looking for at least a gallon air tank.  Was wondering if California Air Tool 1 gal or Campbell Hausfeld would fit the criteria.  My apologies if I mislead anyone to believe one of those very small ones...looking for at least one gallon tank and carry handle.  Moisture not an issue here since it is very dry and I will draw from the tank in any case.
    July 2013
Posted by modelmaker66 on Monday, September 2, 2019 1:46 AM
HighDesertmodeler
I’ve gone through three Asian made compressors since 2001.  Most recently a TCP one...which air regulator fitting threads to compressor housing was the wrong size (they installed the fitting with some sort of expanding sealant...what garbage...cannot be reinstalled properly and a result I don’t have a functioning compressor.  Im calling TCP after Labor Day.)
I was led to believe that TCP were pretty good too. Live and learn I guess. I use an Iwata btw.
Posted by keavdog on Monday, September 2, 2019 3:17 AM
I've been using a 20lb CO2 tank for years.  Blows compressors away...no pun intended.  Silent, zero condensation and less investment.  Take a look.
Thanks,
John
    November 2018
Posted by oldermodelguy on Monday, September 2, 2019 1:36 PM
keavdog
How long does a 20lb co2 tank fill up last, if you don't mind my asking ?
Posted by keavdog on Monday, September 2, 2019 2:10 PM
Sorry, 10lb co2 tank.  Lasts about 18mos or so.
Thanks,
John
    August 2019
Posted by HighDesertmodeler on Monday, September 2, 2019 5:10 PM
I went ahead and purchased a Rooty Tooty compressor from the guys at Spraygunner.  Hope it is good as some mentioned in their reviews.
    August 2019
Posted by HighDesertmodeler on Wednesday, September 4, 2019 12:02 AM
Latest update - I spoke with TCP and told them about the problems with the compressor from not giving adequate air to the threads on air regulator. They’re sending me a new one since mine was on warranty.
    September 2012
Posted by GMorrison on Wednesday, September 4, 2019 1:53 AM
Noise. thats the biggest problem.
I had a Devilbis two cylinder that rumbled.
Then a Craftsman with a big tank, loud as my motorcycle.
Now a little Testors diaphram putt putt. Nice unit.
    June 2014
Posted by Tanker - Builder on Wednesday, September 4, 2019 7:46 AM
Hi;
 Since I retired I have always used Campbel-Hausfield equipment. Have had very good luck with parts and accessories too. It just putts away and then it goes to the Pawn shop Again!
