Can you put enamel paint into a jar that used to hold acrylic paint?
    March 2017
Posted by theflyingdutchman on Friday, July 23, 2021 12:35 PM
Hi,
I just wanted to check if it was okay to put enamel paint into an empty tamiya jar which now only has dry paint on the sides of the jar
Thanks for the help
    July 2003
  • From: On my kitchen counter top somewhere in North Carolina.
Posted by disastermaster on Friday, July 23, 2021 12:42 PM
Might as well do it right the first time.
I'd clean it up first. Let it sit a while with some laquer thinner in it and then clean it up with some 91% ISP then, rinse and dry.
Sherman-Jumbo-1945
"I was so much older then, I'm younger than that now"
    June 2021
Posted by rocketman2000 on Saturday, July 24, 2021 10:14 AM
Yes as long as you clean it well.  I use a suction feed airbrush, so I do that all the time.  If regular paint thinner does not clean it well enough, lacquer thinner will.
