missileman2000
I am using lacquer thinner to thin the enamel paint. I spray at the same distance as I always have.
Since making this thread here, I have gotten some input from another modeling site (name not disclosed here) about this matter as follows:
One Respondant said to me there: I wouldn't premix the paint/thinner if at all possible. Sometimes you absolutely have to, when you do that it should definitely be stored in a bottle with a previously unused cap. Even then, I'd strain it before spraying it.
Cleaning the airbrush is a must too. Disassemble if at all possible, otherwise spray thinner or cleaner through it until it sprays clean, with no color in the spray.
Cleanliness is the main thing. Shoot for "perfect", most of the time you come up a bit short but still very good.
Another responder said: Strain you paint through a disposable filter too.
Yet another responder said: Also, I'm not sure what equipment you are using, but I always take my spray gun apart after every use. I use a Procon PS-290 which is an internal mix gun, so I have to. One other thing I do is cover the bottle opening with Press and Seal and put the cap on without the factory seal. I use a power stirrer too. I mix paint and thinners in small plastic cups.
I responded: Paache H airbrush, single action, came as kit
Paasche 1 oz jars, lids, cork gaskets, siphon lids
Kleen-Strip lacquer thinner
Testors 1/4 oz. jar enamels
Dewalt 1 gallon air compressor without any filtration in air line
Paasche airbrush cleaning kit
mason jars for clean-up with thinner
paint booth station
Another person there said: Add some pipettes to your order, then you won't pour the paint over the crusty edge of the bottle. I buy them by the 100 count from Amazon, last I knew they were around$6- $8 per 100. Then transfer your paint to a mixing jar or your H jar when ready to paint. Thin,stir, spray. If your paint bottle is new you can dump it right into your spray jar. I tend not to store pre thinned paint for more than the length of the project I'm working on. If you do that though, mark the bottle in some way so you know it's pre thinned later on or has some thinner in it so you can more carefully inspect it and treat accordingly. On model cars/trucks for instance there is nothing quite like freshly mixed paint from a known clean source .
Or decanted enamel. The H sprays decanted enamels imo, better than from the can. Especially if it's non hobby paint. I decant Rustoleum 2X if I find the color I want you get 12oz for $5ish. Decant, add a touch more lacquer thinner and it comes out every bit as nice as Testors bottle paints. Paasche H #3 needle
Yet another person said: Yeah, get some 3 ml pipettes.
Lots of folks spray at different pressures. I shoot everything at 20 psi, adjusted with the airbrush valve opened. That's usually about 22 psi closed. I get too much orange peel at higher pressures. But, that's just my preference. I've got a Paasche H that I use on non-body parts and for primer on bodies. #1 tips for touch up work and #3 for everything else. I scribe a mark on each of the tips as a reference point to open the valve/tip the same amount each time. Usually 1 1/2 to 2 rotations. I use my PS-290 for the color coats on the bodies.
I said: I have just ordered:
* VCT MINI INLINE AIR HOSE COMPRESSOR WATER OIL FILTER DRYER (filters dust, oil and moisture)
* Badger Air-Brush Co. 121 Paint Mixer, White, battery-operated paint stirrer
* Ram-Pro 50 Pack of Paint Strainers with 190 Micron Paint Filter, Fine Nylon Mesh Paint Filter Strainer - Premium Grade Paint Strainers Paper Cone Painting Projects
I'm so sick of these botched paint shoots. I need to get serious now!!! Amazon.com had everything I needed.
PS- I was an American army soldier, once younger and thinner. I am beginning to realize a model builder must take good care of his painting equipment like a soldier takes care of his rifle. I know I get lazy, cheap, impatient or complacent sometimes and that can be costly during a paint shoot.
