Mr Leveling Thinner
    July 2019
Mr Leveling Thinner
Posted by Bob D on Friday, May 6, 2022 6:47 PM
Can Mr Leveling Thinner be mixed with STYNYLERS primer?
    February 2021
Posted by MJY65 on Saturday, May 7, 2022 4:56 AM
I don't have any Stynylrez primer to try it, but curious as to your motivation.  Generally, acrylics are used to avoid the fumes and toxicity of solvents.  If you're going to mix it with lacquer thinner, why not use Tamiya FSP, Mr Fine Surfacer or other solvent based primer that works better anyway?
    April 2020
Posted by Eaglecash867 on Saturday, May 7, 2022 5:13 AM
Only one way to find out...Cowboy
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
    November 2018
Posted by oldermodelguy on Saturday, May 7, 2022 8:28 AM
I wouldn't do it. I don't remember my exact reason but suffice it to say hardware store lacquer thinner works much better. I want to say that with MLT the compatability wasn't there but it's been a while since I tried it.
    November 2018
Posted by oldermodelguy on Saturday, May 7, 2022 10:21 AM
MJY65
I will say this: Mr Primer Surfacer stinks to the high heavens, exceedingly above Stynylrez with LT in it. I use both products. I don't always thin Stynylrez and when I do I also don't always use LT in it. But it thins well with LT and the finished result is both a very excellent bond and baby butt smooth finish.
    July 2019
Posted by Bob D on Saturday, May 7, 2022 12:55 PM
What i get here is YES i can use LT in STYNYLERS but i will see. I will try it on a old model and see what happens. Thank you all.
    July 2019
Posted by Bob D on Saturday, May 7, 2022 2:45 PM
OK. I tried Stynylers with alittle LT and it started spitting, kept clogging the tip. I tried it without thinner and it did not clog the tip but i did'nt like the way it covered. I went to my old faithful (Vallejo) and it workes fine for me. I don't intend to sand the primer, so i am not worried about removing the primer. I read all the post and like to try different things. Some may have good results with one thing, while others can't get it to work. But thanks again for the advice.
    November 2018
Posted by oldermodelguy on Saturday, May 7, 2022 6:19 PM
Hah,most folks would argue that Vallejo primer is about the worst you could get in a primer !
I been using Stynlrez about 6 or so years now and had no issues with it. You do need to power mix it now and then. If it settles out from sitting you can mix with a stick till you're dizzy and it doesn't really all go back together. The Badger mixer does it in about 30 seconds. But I do recall that Mr Leveling thinner was not so hot in it as I said in my other post.
Posted by Tojo72 on Saturday, May 7, 2022 6:25 PM
Bob D
I have used Vallejo RAL 7028 Dark Yellow Primer as a base coat with good sucess thinned with their thinner and flow improver,I'm not sanding it,but I have used Tamiya paints to apply the tri-color camo over it with no issues and I like the finish.
So it's about whatever works for you.
    November 2018
Posted by oldermodelguy on Saturday, May 7, 2022 6:33 PM
Just my opinion with sandabilitry aside, I've always suspected that the bad press on Vallejo primer is based on not following instructions. Many modelers are horrible at reading the labels, either that we're all getting so old we can't see the blasted things anymore lol !
