Today at Walmart, I noticed that the automotive department changed their stock to Campbell-Hausefeld products and I wonder if their tanks and other products would be compatible with an airbrush (my Aztek 370).
Tank: Regular 7 gallon with pressure gauge
Air filter: bulb-shaped, catches water and dirt. Small and large available
Air adjustor valve: bar code read as regulator--would this work?
Also, would the filter and adjuster/regulator fit for the tank or are they for compressors only?
