- Member since
January 2009
Posted by eptingmike
on Sunday, May 10, 2009 2:10 PM
mandrake wrote: | Hi, i know you posted this a long time a go but still i hope you can help me out, you see i am having trouble with this new airbrush i got, is a model maker DA400, i already hate this airbrush is so difficult to clean and has way more o-rings than my old reliable Badger 150, so, my question is, are you sure that brake fluid wont damage the inner o-rings? i know you said no, but i dont know what kind of airbrush you have, and to make matters worse, i dont know if model maker DA400 is better or worse than the badger ones, maybe is a low quality airbrush and brake fluid would damage it further more, any words you may wanna share? Thanks in advance Regards Hector. |
Brake fluid is pretty safe on rubbery things. We used to use it(dot 3?) to clean pinch rollers on tape machines when I did audio engineering work. It is designed not to eat through the hosing in automobiles, if I am not mistaken. However, it is toxic and overall, while cheap, it may be better in the long run to pursue an alternate course. mike
