QUOTE: Originally posted by simon waite
Hello Folks,
If I use a different tip could I get better performance. Or are the various tips just good for different paints or inks?
The different needle and tip sizes are made just for the reason you alluded to, different medium viscosities sprayed through the airbrush. If the paint you are using is fairly thin then the #1 tip and needle may produce slightly thinner lines than the #3 tip.
I would recommend the #1 tip and needle for enamels and thin acrylics, but experiment as Greg said above.
Greg has some good advice there I might add.
If spraying larger areas the #3 tip and needle may be a better bet. Try spraying a solid color on a car body for example and you will be making multiple passes and not getting a smooth overlap in your passes. It's kind of like trying to spray paint a real car with a small touch-up gun, it just doesn't work very well.
“Wisdom is the right use of knowledge. To know is not
to be wise. Many men know a great deal, and are all the greater fools
for it. There is no fool so great a fool as a knowing fool. But to know
how to use knowledge is to have wisdom. " Charles Spurgeon
