Hi
I have a Badger 155 Anthem, I'm just getting used to using it.
It's the first internal mix airbrush I have had and I'm wondering how far to go with cleaning it after use.
So far I'm using a clean jar & thinners and I spray it through until its clear. Then I wipe clean the bottom feed hole and the rest of the brush. I have only used it about six times or so, and have found it to be excelent, so I would like to keep it that way!
Should I strip it after each use? although this would seem a bit excessive.
Many thanks
Karl
