Help : portable car tyre compressor
Posted by Anonymous on Monday, September 15, 2003 5:51 AM
Iam from india ( were its really difficult as a modeller)
I have recently bought a portable car tyre comprsor / pump but the problem is that the air is pumped in pulses. I need to know if my idea will work. I am planning to buy a used car innertube and fit a another tube / valve ( so i will have a inlet and a outlet ) to it. So the tyre works a resorvior and i get even pressure
ideas and comments welcome
email id : simba_no1@mailcity.com
    August 2003
Posted by South Aussie on Monday, September 15, 2003 6:10 AM
The innertube will act as a resorvior and reduce pulses but you will need a pressure regulator / moisture trap between the tube and airbrush to be able to fully control air pressure to the brush.
A word of warning the tube should be over inflated or it could blow and cause injuries, fitting the tube to a wheel with a tyre can reduce this hazard.
Wayne I enjoy getting older, especially when I consider the alternative.
Posted by Anonymous on Monday, September 15, 2003 12:02 PM
Yep, it'll work. A few comments though:
- if the inner-tube is 'dirty', you might get dirty air
- those compressors can crank out alot of pressure. You'll need to watch the pressure in the tube so that it doesn't overinflate/burst
- put a regulator on the outlet or you'll get the same psi that is in the tube (which could be pretty high...)
Good luck!!
Murray
Posted by Anonymous on Tuesday, September 16, 2003 1:41 AM
Thanks a lot guy's !!
