A question about Humbrol enamels
Posted by Anonymous on Tuesday, October 7, 2003 9:33 AM
After reading many good things about Humbrol enamels, I think I'm going to begin using them. Plus, they're about $1 cheaper per unit than Model Master enamels. My question is that when I thin the paints to airbrush them, what thinner should I use and to what ratio should I thin the paint? TIA
    May 2003
Posted by styrene on Tuesday, October 7, 2003 11:03 AM
I've mixed Humbrol enamels (some years ago), and used about an 80(paint):20 (thinner) with good results. A lot of the mixing is really going to depend on your airbrush, pressure, and what you are trying to achieve.
A regular mineral spirits thinner should do the trick.
Gip Winecoff
Posted by Anonymous on Wednesday, October 8, 2003 3:45 AM
humbrol thinner, even white spirit is fine......some of the colors are fine but humbrol proposes lots of mixing for accurate shades, however with a bit of weathering and light/dark applied it will yield just fine unless you are too picky and use spectrograph to get the right shade..lol
    May 2003
Posted by qmiester on Wednesday, October 8, 2003 6:32 PM
I've had very good luck with Dupont fast dry enamel reducer #3812S - works very well with both Humbrol and Model Master - I buy it by the gallon (Last one was 16.95 - which beats 2.50 for 2 ounces at the hobby shop) - that should last me about a year or so - check your local auto supply store or the phone book under auto paints - I'm pretty sure you can get it in pints and quarts too
I thin the Model Master 50/50 and Humbrol 30/40 percent paint to 60/70 percent thinner and spray it at 12 to 20 psi - If I'm going to paint narrow lines I raise the ratio of thinner to paint by about 10 percent - You'll need to experiment to find out what works best for you - good luck
Quincy
Posted by Anonymous on Thursday, October 9, 2003 11:36 PM
All I own is Humbrol Enamels and find them very good , I thin them with about 50% thinner , I just use general purpose thinner because I get it free from work. I haven't had any problems with this method.
