- Member since
Iwata HP-CS is spitting a little bit
Posted by Anonymous
on Monday, October 20, 2003 4:53 PM
I just started using my new Iwata HP-CS for the first time the other day. This is my first time to ever use an airbrush, so please forgive my lack of knowledge in this area. The first time I ran paint through it, it seemed to do OK. The next time I used it, it seemed to spit large large paint particles out a little bit. I cleaned the airbrush very well after using it the first time. I'm spraying Model Master enamels properly thinned through the airbrush, about 3 to 1 ratio using Testors airbrush thinner. Anyone know what might be the problem? On dual-action airbrushes, do you ALWAYS depress the trigger and let the air flow all the time, and just pull back on the trigger when you want to release the paint or what? When I cleaned it, I took the needle out and cleaned it with mineral spirits, and then lubed the needle with Medea airbrush lube. If you are spraying the same color and waiting about 30 minutes between sessions, is it necessary to clean out the paint cup and clean the nozzle before beginning again? Any thoughts, recommendations, or "hey, dumb@$$"es appreciated!!
