Tamiya X22 clear coat
Posted by Anonymous on Wednesday, October 22, 2003 9:43 AM
I'm new to using this type of clear coat, I have only used automotive clear coat in the past, but it is very toxic.
The question is, is it airbrush ready or do I have to thin it? What's the thinner/coar ratio?
Another question is, I have the X21 flat base, what's the ratio for semi gloss and flat cleat coats respectively?
Thank you.
Posted by djmodels1999 on Wednesday, October 22, 2003 9:46 AM
Thin it with isopropyl alcohol, or the Tamiya thinner (more expensive option). As for ratio, experiment, but you'd need something that has the consistency of milk.
I only use the flat base to represent frost on the ground, so I can't help you there...
Posted by Swanny on Wednesday, October 22, 2003 10:21 AM
Flat base at 30%
Posted by Anonymous on Thursday, October 23, 2003 1:15 AM
Swanny,
What do you mean by 30% ? Is that like 1:3 ratio or 30 X22 70 Thinner ? I can certainely agreed with DJmodel1999 about the frost application.
