What is the best way to clean an airbrush, bearing mind I only use acrylics?
Currently I spray through a strong solution of windscreen washer fluid and water, for around 30 seconds or so.
Then I spray clean water another 30 seconds or so, until the water runs clear.
If I am leaving the airbrush for any period of time, I dump it in a solution of windscreen washer fluid and water, often leaving it overnight, before dissembling and rinsing in clean water.
Any paint that may have accumulated on the needle I remove with an ink rubber as reccomended by Badger.
Is there anything else I should be doing?
Thanks
Karl
