Decals on Future.
    July 2010
Decals on Future.
Posted by roony on Sunday, March 16, 2014 10:46 AM
I tried for the first time, laying the decal into a wet coat of Future. It worked great. I see no silvering (which is unusual for me). But now? A: Do I give it a coat of Future, then Tamiya Flat TS-80 B: A coat of Tamiya Clear TS-13, then Tamiya Flat C: Can I just go with Tamiya Flat? Being lazy, my preference is C. Do I need a Clear Coat first?
    November 2008
Posted by plasticjunkie on Wednesday, March 26, 2014 9:32 AM
Brush another coat of Future and let it cure for a day or so, then spray clear flat acrylic over to kill the gloss.
 GIFMaker.org_jy_Ayj_O
    December 2006
Posted by Fly-n-hi on Wednesday, March 26, 2014 1:29 PM
Be aware when using this technique that the decals are permanent.  Once the Future cures there will be no going back.  If you place the decal on top of the cured Future you can still re moisten it and move it later if you need to.
    July 2010
Posted by roony on Thursday, March 27, 2014 10:44 AM
Thank you for the input.  I went with plan B.  There was another post the same day as mine, with the same question, & I was following it.  There are always so many ways to do the same thing.
    December 2011
Posted by Chrisk-k on Thursday, March 27, 2014 1:52 PM
I recently adopted the wet Future technique and love it. I always go with plan A to protect decals from oil washes and weathering.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    January 2014
Posted by Silver on Monday, August 4, 2014 11:13 AM
It's best to get away from using Future and start on Testors Gloss,Gloss non-spar Varnish,orAlclad Kristal Coat.
    July 2014
Posted by teejay on Friday, October 17, 2014 12:53 AM
"It's best to get away from using Future and start on Testors Gloss,Gloss non-spar Varnish,orAlclad Kristal Coat."
I'm new to this. Is the testor gloss you're referring a brush on or rattle can? Can you use gloss spray can on the decal after applying it to seal it?
    November 2008
Posted by plasticjunkie on Friday, October 17, 2014 7:01 AM
Silver
Future doesn't yellow over time as lacquer may over white paint. Future can successfully attach stubborn decals that refuse to stay down and curl. Future will get rid of the  "step" effect from thick decals. Future can be hand brushed producing glass smooth surface. One model car builder was featured on a FSM article where he hand brushes Future as a final gloss coat on his model cars.
Future will also produce a barrier coat for solvent based washes. Lacquer gloss or flat will dry very fast and produce nice finishes but Future has far more advantages than the latter product.
I use both Future and lacquer but depends on what I need it for.
    November 2008
Posted by plasticjunkie on Friday, October 17, 2014 7:07 AM
teejay
I would refrain from brushing clear lacquer because it is very strong and will lift fresh paint up. It is best to spray it for best results. It is probably ok to brush over cured paint but I rather spray it.
Posted by Texgunner on Friday, October 17, 2014 8:01 AM
I've never had a problem with Future that wasn't "operator error". Wink There may been folks having problems with some new version of Future, but the original formula is a very good modeling product.  Your mileage may vary of course.Cool
Gary
Oh, and by the way, happy Friday to everybody...Viernes por fin!
"All you mugs need to get busy building, and post pics!"
    November 2008
Posted by plasticjunkie on Friday, October 17, 2014 9:21 AM
Feliz Viernes to you too Gary, LOL. I'm down to a little above half so I still have a couple of years to go before my mileage runs out. :ohnoes:
