Tips on using Archer rivet decals?
    May 2011
Posted by Real G on Tuesday, May 19, 2015 9:24 PM
As the subject says, has anyone used Archer's resin rivet decals?  If so, any pointers that I should be aware of?  I am going to be using them on the flat bottom of a racing car, so at least my first try will be fairly straightforward.  I am hoping the decals work well, as I have another project that will require a considerable amount of rivets.
“Ya ya ya, unicorn papoi!”
    April 2006
Posted by jgeratic on Tuesday, May 19, 2015 11:51 PM
I have used them, but couldn't get them to curve around corners like their instruction video shows on youtube.  Basically apply them like decals, I had success on straight level applications with future clear as the wet medium on the model's surface.
regards,
Jack
    May 2011
Posted by Real G on Wednesday, May 20, 2015 1:48 PM
Thanks Jack!  I noticed in the instructional video that the guy used scissors to cut rows of rivets off the sheet.  Would a straightedge and knife be better, or would that risk knocking off the rivets? I don't have any confidence in cutting nice straight lines with scissors.
    April 2006
Posted by jgeratic on Wednesday, May 20, 2015 4:46 PM
Can use both, but for longer cuts like single rows, it's easier to see what you are doing with a knife and straight edge.  Trying to hold a thin strip and trimming with scissors would be difficult, unless you are cutting directly from the sheet and working from the outside edge.
regards,
Jack
    August 2008
Posted by tankerbuilder on Friday, May 22, 2015 8:30 AM
I noted your comment about curves , Now , it seems that I had no problem there . My problem was getting them to settle down on some surfaces .
