Dry transfer decals
    June 2014
Dry transfer decals
Posted by VillageBob on Saturday, June 13, 2015 10:35 AM
Has anyone ever used Archer dry transfer decals ? if so opinions
Tags: Decal , transfers
Just saying to all model builders
    December 2011
Posted by Chrisk-k on Saturday, June 13, 2015 12:19 PM
Very easy to use and looks truly like it's painted because it's actually painted on the model.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    September 2012
Posted by GMorrison on Saturday, June 13, 2015 12:55 PM
Never used archer, but I use woodlands scenic etc. a lot.
Name on the bow for instance.
    May 2009
Posted by Pawel on Saturday, June 13, 2015 1:09 PM
Hello!
Archer transfers sometimes causes problems with application - mostly when they haven't been stored right, they tend to be very tough to separate from the backing paper. This is especially tough, when applying them to tight corners etc. BUT the customer service is just superb, they replace any sheets that cause problems and - look out now! - replace any sheets that have been used up at no cost to the modeller! Plus their research is very solid, so Archer is definitely worth a try. Good luck with your build!
Paweł
www.vietnam.net.pl
Posted by Don Stauffer on Sunday, June 14, 2015 11:11 AM
I like them.  I also have used other brands, like Letterset.  Archer is nice because they work on sheets of more interest to modelers.  Other brands are more generic, mostly various fonts in black, white or gold, and some symbols.
    May 2013
Posted by Greg on Sunday, June 14, 2015 12:01 PM
Do these work over slightly irregular surfaces? Say an injection-molded old wooden boxcar side, or maybe a recessed panel line on an aircraft?
I used dry transfer all the time for presentations and stuff before home computers and printing, can't believe I never tried them on a model.
    May 2009
Posted by Pawel on Sunday, June 14, 2015 3:24 PM
Hello!
Yes, they work over slightly rough surfaces - when you get them to separate from the backing sheet, you can stipple them down the irregularities and there you have it - painted on look!
Hope it helps and good luck with your projects
Paweł
www.vietnam.net.pl
    May 2013
Posted by Greg on Monday, June 15, 2015 5:20 PM
Thank you for that information, Pawel. In that case,  I look forward to trying one day.
Posted by Tojo72 on Tuesday, June 16, 2015 10:17 AM
I had trouble with them,it was easier to get water-slides to go over zimmerit for me.
    May 2013
Posted by Greg on Tuesday, June 16, 2015 10:25 AM
Tojo72
Interesting, and I'd expect as much. Wonder if anyone has had success over a really rough surface like zimmerit?
    September 2012
Posted by GMorrison on Tuesday, June 16, 2015 10:27 AM
I think that's asking...a bit much.
    May 2013
Posted by Greg on Tuesday, June 16, 2015 10:48 AM
I reckon so.
    June 2013
Posted by RobGroot4 on Tuesday, June 23, 2015 1:38 AM
Greg
Greg,
  I'm more of an aircraft guy, so I can't speak to Zimmerit, but I used some dry transfer straight lines from woodland scenic to do the yellow rings on some modern USN GBU bombs.  I had created a rough non-skid style texture on the bomb casings with baking soda that I rolled the bombs in while the initial paint was wet.  After a topcoat of paint dried I applied the dry transfers and burnished them down with a rounded off toothpick.  The transfers were really nice because the burnishing sank the markings into the grooves and crevices perfectly and I didn't have to worry about silvering.  Also, even though I was using straight line sections, I was able to get them to curve around the conical bombs with no problems.  To apply the markings I separated the line from the backing, stuck an end down, and then burnished short sections, pulled the next part down onto the bomb, and burnished some more.  Doing one bomb only took me about 5 minutes for both rings.  I hope that helps.
Groot
"Firing flares while dumping fuel may ruin your day" SH-60B NATOPS
