Microscale Microsol Flat
    December, 2002
Posted by Bill Clarke on Sunday, November 04, 2018 12:50 AM
I sprayed this on a model as a flat coat after weathering (no decals) but the model appears to have a satin surface now, did I use it incorrectly?
    December, 2002
Posted by Bish on Sunday, November 04, 2018 3:14 AM
Are you talking about Microsol or the Microscale Flat varnish. Microsol is a decal setting soloution and is not meant to be sprayed on the model.
If it is the varnish, it could be its not been mixed properly. I used to use it until a few years back but had some many issues with it i switched to somthing else.
'I am a Norfolk man, and i glory in being so'
On the bench: Dragon 1/72nd Ar 234B-2b
                      Airfix 1/72nd SM.79
    January, 2013
Posted by BlackSheepTwoOneFour on Sunday, November 04, 2018 11:35 AM
I did a search for the so-called Micro Sol “flat varnish“and didn’t find such a product. Micro Sol and Micro Set are both used for dealing, not a clear coat varnish finish.
    April, 2013
Posted by KnightTemplar5150 on Sunday, November 04, 2018 2:07 PM
    December, 2002
Posted by Bill Clarke on Sunday, November 04, 2018 3:45 PM
Yes, that's what i used, I've used it before as a flat coat, and it worked nicely, I thinned it with denutured alcohol, as spraying straight out of the bottle wouldn't work.
    April, 2013
Posted by KnightTemplar5150 on Sunday, November 04, 2018 4:03 PM
The denatured alcohol may be part of the problem. This stuff is supposed to cut with water when airbrushing. On the manufacturer's website, you can find specific instructions on diluting the flat coat for best results.
    December, 2002
Posted by Bill Clarke on Sunday, November 04, 2018 9:33 PM
Well it says on the bottle thin with water or alcohol, and i used 70% Isopropyl alcohol.
    September, 2012
Posted by GMorrison on Sunday, November 04, 2018 10:15 PM
That's the confusing part of the OP. It's not Micro Sol Flat; it's Micro Flat. I have never heard of this one, but thanks for introduction.
    January, 2013
Posted by BlackSheepTwoOneFour on Sunday, November 04, 2018 10:15 PM
KnightTemplar5150
Nice catch. I couldn't find it in Micro Mark website.
    January, 2013
Posted by BlackSheepTwoOneFour on Sunday, November 04, 2018 10:17 PM
Bill Clarke
I probably would have used universal acrylic thinner instead.
    January, 2013
Posted by BlackSheepTwoOneFour on Sunday, November 04, 2018 10:19 PM
GMorrison
Me neither. We all learn something new everyday - even the oddball products.
    December, 2002
Posted by Bill Clarke on Tuesday, November 06, 2018 3:29 PM
Bill Clarke
What is a "universal thinner"?
    November, 2008
Posted by plasticjunkie on Wednesday, November 07, 2018 7:03 PM
That product has been around for ages. I have a couple of bottles 20+ years old. I believe mine which is the old formula thins with LT but the current one thins with water.
 GIFMaker.org_jy_Ayj_O
