Decals on a matt paint surface
    February 2013
Posted by Raven Morpheus on Tuesday, May 14, 2013 7:38 AM
Sorry I know this has probably been covered before but I am looking for some advice that is more specific to my current model build.
I'm building a UH-1D (those viewing the Helicopter sub-forum probably already know this) and the main body is sprayed with Humbrol #155 matt OD.
I've got to the stage (just about) where I'm thinking of applying decals.
However I have some concerns about doing so, especially as I've just purchased some very good decals that I don't want to mess up.
1.  I understand the concept of applying decals over a gloss surface.  However I don't currently have a spray can of gloss varnish, and I don't have an airbrush to apply Future (or similar products) with.  I am considering masking the area a decal is going onto with masking tape and then applying Future with a brush to that area, removing the masking tape, and then applying the decal.
Would I run into any problems doing that?  Would I be better off spraying the entire model with an gloss varnish such as one by Humbrol (#35 looks like the one I'd buy), applying the decals and then respraying the entire model with a matt varnish?
2.  How do I stop parts of the decal, such as the centre of a circle decal, showing the clear film - in the past I've applied decals (and painted around the edges to disguise the clear film) but I could always see that the clear film is visible in parts where the decal isn't printed.
Many thanks in advance for any advice on this.
Posted by VanceCrozier on Tuesday, May 14, 2013 8:14 AM
Hey Raven - The answer to question #2 is... answered in question #1. You need a super-smooth surface . Decal film "showing" is (to over-simplify things here) air pockets that are produced by matt paint. So... to avoid this, you really do need a gloss coat of some sort. I prefer Future myself as it doesn't stink up the house, and it's cheap! I wouldn't recommend spot-applying the Future though, as I find it often darkens the matt paint that is underneath. So you'd avoid the decal-silvering, but you'd have a dark patch around it. Also, I almost always apply my Future with a good paintbrush rather than airbrush - the stuff self-levels, right!
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
Posted by Don Stauffer on Tuesday, May 14, 2013 8:59 AM
I have never noticed future darkening my flat paints, so I brush it on spots that will have decals.  The only finish I have noticed an adverse effect on is Alclad, and that effect is so slight I don't worry about it.
Posted by VanceCrozier on Tuesday, May 14, 2013 9:06 AM
Don Stauffer
"your results may vary!"
    February 2013
Posted by Raven Morpheus on Tuesday, May 14, 2013 9:43 AM
Hmm so it's a case of "suck it an see" I guess.
I'm not too keen on painting the entire model by brush due to the possibility of putting on too thick a coat (one of the reasons I used a spray paint to put the base coat on), but looking at the cost of a spray can of gloss varnish (£5+) and considering I have a bottle of Future (albeit from 1997) perhaps brushing it on the whole model might be the best route.
Just need a larger brush, I've ordered an Italeri size 6 brush from an ebay seller today as I currently only have a couple of Game Workshop detail brushes, hopefully a size 6 will be large enough.
If I do only apply it to a specific area only and it does darken that area I can always just paint the rest of the model with Future - right?
Posted by Tojo72 on Tuesday, May 14, 2013 10:31 AM
Is it a problem to get a can of gloss varnish and some flat clear,that would solve this and future problems ?
Posted by VanceCrozier on Tuesday, May 14, 2013 12:00 PM
Raven Morpheus
lol, pretty much. I've seen the darkening happen a lot on my Tamiya Acrylics, maybe they're more sensitive than other paint?
Raven Morpheus
The bottle of Future that I'm using is, well, "of a similar vintage", probably 98 or 99. I've got a good angled brush that is probably no more that 1/2 inch across. I just work in small sections, every stroke in the same direction as long as possible, no going back over the brush stroke (unless I've loaded too much on the brush & see a "run") I often have to make a second application because I do use thin coats to avoid the chance of having too thick a layer that could run.
Raven Morpheus
Exactly.
    February 2013
Posted by Raven Morpheus on Tuesday, May 14, 2013 12:47 PM
Yes it is a problem.  I have a very limited budget.  I will buy the matt varnish (flat clear or whatever you wish to call it) anyway, but if I can save £5 by using something I already have to hand then that's £5 I can spend on other tools/materials that I don't have and might require.
@VanceCrozier - thanks.
    May 2009
Posted by Pawel on Tuesday, May 14, 2013 12:50 PM
Well - a word of warning here. If you apply a spot of future and it darkens the paint, you probably won't be able to remove the darker spot by recoating. At least this worked this way for me, when I applied our local Future equivalent over airbrushed matt Humbrol. To avoid it, I'd spray the whole model with water, to make it slightly wet, and then apply Future with a brush, or airbrush Future on the model. Adding just a tiny little bit of soap or dishwashing liquid helps to do it, too. Hope it helps, have a nice day
Paweł
www.vietnam.net.pl
    February 2013
Posted by Raven Morpheus on Tuesday, May 14, 2013 1:04 PM
Thanks Pawel.
Just out of interest when airbrushing Future do you have to thin it at all, if so what do you use?
I've just been looking around for a very basic inexpensive airbrush/spray gun and come across this that I might buy for doing gloss layer ready for decal application -
www.ebay.co.uk/.../390508072566
    October 2008
Posted by padakr on Tuesday, May 14, 2013 2:36 PM
I've spot applied Future and other gloss acrylics with a brush and sometimes had the "darken effect".  A coat of flat took care of that for me.
Paul
    May 2009
Posted by Pawel on Tuesday, May 14, 2013 3:57 PM
Hello!
I thin it just a little with water, and I add a really small amount of dishwashing liquid to it, to improve the flow. I tried many things to remove my "darken effect" but it seems to be very stubborn, so watch out not to let it happen. Good luck with your projects and have a nice day
Paweł
www.vietnam.net.pl
    May 2013
Posted by payopl on Friday, May 31, 2013 9:03 AM
New decals:
www.youtube.com/watch
