Big Decal Problem
    June 2013
Big Decal Problem
Posted by RobGroot4 on Wednesday, January 8, 2014 8:24 PM
I'm hoping someone can help me out, I'm building a 1/48 F/A-18C with with a large single-piece decal for the vertical stabilizer.  The decal is the squadron logo as well as the background colors, so it covers the entire piece (about an inch wide at the top, two inches wide at the bottom, and 2.5 inches tall).
I'm running into trouble with the raised bumps on the stabilizers and getting the decals to settle down over them.  I fortunately had two set of these decals.  I coated the pieces with future and let dry for several days before decaling.
I started with micro set on the piece and transferred the decal to the part easily enough.  I could not get the decal to settle into the recesses between the raised antennas on the trailing edges.  After letting the decals get mostly dry, I tried solvaset initially but was still left with some bubbles under the decals in the recesses.  I tried puncturing the decals with a pin after they were dry and applying more solvaset.  I couldn't get the bubbles to go away and the decals started cracking up.
I am working with the second set of decals and trying micro sol as it's less harsh than solvaset.  I'm starting to see that it doesn't seem to be really getting the decals to settle down.
I fortunately found a third set on ebay that should be here tomorrow, but was wondering if someone could make any suggestions on how to get the decals to settle down nicely into the recesses without wrecking them.  Thanks!
Groot
"Firing flares while dumping fuel may ruin your day" SH-60B NATOPS
    March 2010
Posted by Nathan T on Wednesday, January 8, 2014 9:20 PM
Any chance you could paint the background color and then trim the decal smaller?
Posted by Don Stauffer on Thursday, January 9, 2014 9:33 AM
I have had this problem with larger bumps and not too flexible decals. I have resorted to making star shaped cuts over the bump.  When I finally get the decal down, however, this leaves marks uncovered by the decal, so you have to match paint and paint the bump.
When to press down on decal with something like a Q-tip is tricky.  Some folks say never press down or touch decal after applying solvent, but sometimes you have to!  You need to wait a few minutes, and the right time is critical.  Wait too long and you may damage decal.  This is one of those things you learn by experience.
    June 2013
Posted by RobGroot4 on Thursday, January 9, 2014 8:42 PM
Thanks for the help!  If I'm going to have to attempt to match paint (I was really hoping to avoid this), I think I may try carving the decal up and see if I can get the background dark blue close enough to work with.
I tried pushing down with the first set after they were shot (since they were, might as well experiment a little right!) and that is definitely beyond me!
Thank you!
    March 2006
Posted by daiguma on Monday, February 17, 2014 9:31 PM
Try using the Future for your setting solution. As it dries it will suck tight to the surface and no silvering
"Live life to the fullest and die without regrets"
    April 2013
Posted by FlyItLikeYouStoleIt on Monday, February 17, 2014 10:39 PM
RobGroot4, I'm thinking along the same lines as daiguma. You said you first applied Future, then let it dry several days, right? I apply decals using Future when it's wet. Apply one coat and let it just start getting tacky. Then, after soaking the decal in water, I apply more Future to the model and immediately slide the wet decal to the wet Future. Keeping a fine brush wet with Future, I position the decal and push out bubbles, moving rather quickly as the Future will get tacky pretty quick. Once the decal is positioned, I use a larger brush with Future and go over the entire decal then leave it alone.
This method acts as both a decal application solution and decal set simultaneously and once dry, it's never going anywhere!
Bill.
On the bench:  Lindberg 1/32 scale 1934 Ford Coupe and a few rescue projects.
In queue:  Tamiya 1/35 Quad Tractor or a scratch build project.
    June 2013
Posted by RobGroot4 on Tuesday, February 18, 2014 5:12 PM
Thanks guys, I was able to cut out the decal and come up with a decent background color that works pretty good (Tamiya Dark Blue).  I will definitely try the future thing next time.  I'm not sure why the decals were set up to cover the entire vertical stabilizer, it would have made more sense (to me!) to just provide an FS number on the background and make the decal the white, yellow and orange markings for the squadron logo.  Here's what the decal looks like, the difference on the one I'm working with is that there is a horizontal orange stripe at the top with CAG written in dark blue (I'm doing an F/A-18C, the image below is an E but the logo hadn't changed much when this was painted).  Thanks for all the help!
Groot
    January 2014
Posted by Silver on Wednesday, July 30, 2014 9:50 PM
Nathan is right .Paint the bsckround then trim the decal ,or avoid the version.
