Argh!! A little advice please?
    September 2013
Posted by DeafAviator on Saturday, February 22, 2014 10:41 AM
So I've had a problem the past couple kits I've been building. I'm seeing a lot of silvering and extremely weak adhesion of decals. Washes go right under them even after being clear coated, they don't stick well (will come off if lightly rubbed after dried), they silver something ugly, and masking tape is guaranteed to rip them all off. This is with kit, aftermarket, and self-made decals. I tried future - dried as well as applying them on wet/drying future, microset/sol, plain water, etc etc. it seems like the decal adhesive is just disappearing. What am I doing wrong?? I normally love doing decals but with several decals lost to masking or normal handling, and everything with a clear carrier is horribly silvered, I'm not loving it so much anymore...
Todd Barker - Colorado Springs, CO
Current Projects:
  • 1/48 Beechcraft Bonanza - N51HM (Commission)
  • 1/48 B-25 Mitchell - Back Burner/Scheme TBD
    April 2009
Posted by Cadet Chuck on Saturday, February 22, 2014 10:52 AM
Maybe you're letting them sit in the water too long and rinsing away the adhesive. I dip them, one at a time, in warm water for about 10 seconds, then take them out and let them sit face up on piece of paper towel until they just begin to slide loose from the backing, then apply to the model immediately. After a few minutes, when they have stuck to the model, I give them a coat of decal set.  (not solvent, until later if needed.)
    March 2010
Posted by Nathan T on Saturday, February 22, 2014 2:36 PM
What decal brands? What gloss coat brands? What type of washes? As far as silvering, just remember the decal and clear film will look exactly like the surface underneath, regardless of using setting solutions. If your gloss coat looks rough and pebbly, so will the decal, no matter what.
    September 2013
Posted by DeafAviator on Saturday, February 22, 2014 5:12 PM
I think Chuck may have something - I was trying to do a "production line" type of deal: drop about 10 of them, then knock them all out (this would sometimes result in decals sitting, ready to be applied, for several minutes). I think by doing so, I was eliminating the adhesive properties of the decal.
Current Projects:
    March 2010
Posted by Nathan T on Saturday, February 22, 2014 5:47 PM
Yeah sounds like it just may be your procedure. I only dip about 2 at the most at the same time.
    September 2013
Posted by DeafAviator on Saturday, February 22, 2014 5:58 PM
Gotcha - thanks Nathan!
Current Projects:
Posted by Don Stauffer on Sunday, February 23, 2014 12:24 PM
When you say you use future, when do you us it?l  Before decaling, letting it dry, or as a decal setting solution. If I clearcoat an area on flat paint, I let it dry thoroughly before starting decaling.  Silvering is generally caused by putting the decal down on a microscopically rough surface.  The surface needs to be smooth at a microscopic level.
    March 2010
Posted by Nathan T on Sunday, February 23, 2014 7:42 PM
DeafAviator
You bet. Not to say I never have my own decal problems though!
    November 2008
Posted by plasticjunkie on Thursday, March 6, 2014 7:33 AM
I don't see how a decal can lift if...you brush Future on the area, slide the decal over the wet Future that will bond it to the surface within a few minutes, then brush on another coat over the decal. I use this method on stubborn decals and to eliminate silvering and it works every time.
 GIFMaker.org_jy_Ayj_O
    December 2011
Posted by Chrisk-k on Thursday, March 6, 2014 4:36 PM
plasticjunkie
I second this.  I was not good at decaling, but since I started to use the wet-Future method, decaling has become fool-proof.  No lifting, no silvering.  My Micro Set & Sol are collecting dust.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
