Just read some posts to this forum concerning Future floor wax from (I think) 2011. Anyway, in those posts I read that you can apply a bit of Future and then place a decal on the still wet Future, wait until it dries and then put more future over the decal. First question: does this method negate the use of micro-sol and micro-set? Second question: if I sand down the Future I covered the decal with what grit sandpaper should I use (I was thinking something around 800 or 1000 wet or dry)? Third question: will sanding the Future from the top of the decal have a tendency to fade the decal?
Thanks, Dave
I have tried future as a setting solution and don't think it works as well as the real stuff, which is usually acetic acid (dilute). Another help is to add just a tiny drop of detergent to the water you dip the decals in.
I know some folks who use vinegar as a wetting/setting solution because it is cheaper than the hobby shop stuff. Be very careful. Even so-called "white vinegar" often has dissolved solids in it that can leave deposits on the surface.
Thanks, Don. Don't want to mess up the decals on the next build (planned: 1/32 Avenger from Tamiya). Think I'll try the water/dish soap solution (just a drop). Still would like to know if sanding a topcoat of Future will "fade" the decal some. To me, this is a desireable effect especially when it comes to weathering.
Dave
I don't believe sanding the Future or any clear coat, would "fade" the colors of the decal. That would be best accomplished by air brushing a light coat of say thinned buff or beige or light gray or what ever over the decal during you weathering phase then finally covering with your final top coat
Steve
Building the perfect model---just not quite yet
Future will leave a visible stain or blemish on any painted surface. I no longer use it that way. Yes, it will seal a decal, but it will always be visible if you look closely.
Sanding Future on top of a decal will likely ruin the decal. I find this stuff to be greatly overrated. I'll use it for dipping canopies as it works well for that, otherwise, I'll let the wife use it on floors.
Cadet Chuck Future will leave a visible stain or blemish on any painted surface. I no longer use it that way. Yes, it will seal a decal, but it will always be visible if you look closely.
Any clear coat will leave a stain. I spray Future after decals are dry, and the original stains are invisible. A final satin or matt coat makes original stains completely undetectable.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
Thanks for the info, folks. Just what do you guys mean concerning a stain? I thought that covering the whole model with Future after the decals were set would give it a nice clear gloss (and protect the decals) then I could cover that with a flat clearcoat (like Testor's dullcote). Of course I'm talking about using a lacquer over an acylic. Don't know that that would work. If you can suggest another flat clearcoat I'd appreciate it.
Perhaps "stain" was not the right word. I see it more as a difference in glossiness between the paint and the part over which Future was applied. Chris is right- usually another clear coat over the whole model will make this invisible.
So my plan is to paint the panel lines (pre shade) paint base coat colors, cover with Future, decal, cover with future again, weather, paint on dullcote (or an acrylic flat clear). Sound about right? Or did I miss a step somewhere?
The Future trick works only if there are no raised details. The area has to be flat. Future can be used over thick decals to get rid of the step created by the thick film and yes you can lightly sand it to help blend a thick decal.
This is a perfect example: The 1/25 Academy Panther has decals that did not want to stick very well, not even with multiple applications of Solvaset which is VERY strong. The decals are also very thick and leave a step that is very visible. Here I applied Future to the area and slid the decal in place then waited for a couple of minutes to give the underlying Future to grab the decal. I then brushed on multiple coats from the center of the decal out feathering the effect. Once I was satisfied with the applications I let it cure for 2-3 days then came back with a 4000 pad and lightly sanded till it got a white haze on the area. The sanding is usually not needed but I wanted that thick decal to blend in. The area was wiped clean then I shot some MM flat clear and it looks as if the numbers were painted on.
